Sunfire Yellow 67 Big Block Tearing Up the Track!
Check out this hot Sunfire Yellow 67 corvette tearing up the track!
http://s760.photobucket.com/albums/x...ellowVette.flv
I had fun getting the cars to run again. Found a website that described how to clean the small Japanese motors (yikes in a corvette??). Seems the thing that stops them from working is carbon build up on the brushes. Took the small motor apart and cleaned the brushes with some WD40. Have to be careful as there are 3 small washers/spacers in there that easily fall out. Put everything back together and I had a running car. The vette holds the track well but the camaro has a hard time making it around the track. Its driving tire has a flat spot on it! Anyway, had some fun getting everything back in working order.
Kirk
Kirk
