Frustrating Shifter Linkage issue
I've got a sporadic shifter issue on my '66. Occasionally it locks up so I can not shift gears. When it does this, the shifter feels like it is going into reverse but the car is actually still in a forward gear. I manually have to move the shift rod (usually the middle one) to get it to engage. When I'm trying to shift when this is happening, it almost looks like the shifter itself is locked up. This is extremely frustrating as I've had to drive for the last two weeks with the shifter boot removed so I can get at the rods. This happens only occasionally and only after I have stopped, shut the car down, and then go to restart it and go.
Does this sound like a linkage adjustment or shifter issue?
Any advice would be appreciated as I'd really like to put the shifter boot and console cover back on properly.
Thanks in advance
Al T.
Thanks in advance
Al T.
I don't know what it is but I do know a cure. Buy a Hurst. If you want it to look original, buy the handle from CA or one of the other corvette parts dealers. You can use the original shift rods from the Muncie, except the reverse unit. Also, if you do this, buy the steel bushings for the shift rods. Don't use the fiber ones. JMO
There is nothing in the trans that will keep it in a gear, that is a function of the shifter. The muncie shifter was just OK when it was new, add 40 odd years and it is good for use as a wheel chock.
Hurst with the stock looking handle
If you can jack up the car and get underneath it would be easy enough to check the linkage adjustment per the service manual. If it's aligned, then your shifter is probably worn. Now with that being said with the other posters that the Hurst is the way to go. Corvette Central sells a very nice kit (CC p/n 532042) that includes new Hurst shifter, look alike handle, and all new linkage. I installed this in my car and it was a night and day improvement over the original sloppy shifter and looks completely stock. I'd never go back to the old set up after this. This is one of the best upgrades for driveability you can make. Pilot Dan
Received 1,857 Likes
Volunteer Vette sells an excellent rebuild kit for the stock Muncie shifter - I wrote a photo-illustrated technical article on that rebuild in the January '08 issue of "Corvette Enthusiast" magazine. A correctly assembled and lubricated stock shifter works very nicely; if you're going to be banging gears 1/4-mile at a time, a Hurst Competition-Plus shifter is a better choice.
Would you happen to have a scanned copy of the article? I'd just as soon keep the stock shifter.
Thanks in advance.
Al T.
Its just a little loose. Common problem. You can take it out and repair it without much problem. In the mean time, make positive shifts. Don't get lazy and slide it out of reverse before you get to the gate.
Well,
I received the rebuild kit from Volunteer Vette this week (I hate UPS, brokerage was 60% of the kit price, how they get away....... that's another topic for another time) and was wondering if there's any "tricks to removing the shifter for the rebuild?
Thanks in advance.
Al T.
Thanks in advance.
Al T.
I am not sure on the rebuild kit because I sold my 64 several years ago. But I took some bronze shims that were impregnated with something. My friend got it for me from his work in the aircraft industry and I put them in and tightened the shifter and it worked great. Now I think I ordered that rod for the reverse and It rattled so bad i kept a towl in the car to cover it up from the noise. I would like to see what all your rebuild kit has in it. If you could post some pics.
Received 1,843 Likes
When you pull it out of reverse, you can reef the shifter back and forth sideways and shake the linkage in the neutral gate.
Also agree in the shifter is cleaned/lubed/tight, you can't beat it for a street shifter.
Ray
If you enjoy crawling under your car at the side of
the road and in parking lots, just rebuild it.
I used 2 GM kits to rebuilt 2 factory shifters, to no
avail, and then bought an old Hurst, which not only
has been flawless for the last 15 years, but also
doesn't rattle like the factory shifter.
Then again, there's nothing like getting dressed up
to take your wife somewhere special, only to have
her stand around and watch while you dig out the
jack and find something to use for a jackstand, so
you can ruin your clothes and burn your skin on a
hot exhaust pipe.
hot exhaust pipe.
I hope the original poster from 2 years ago wasn't waiting this long for info.
I had this issue as well (for many years) - until this year when I replaced the 44 year old shifter with the new unit sold by Volunteer Vettes. No more binding and it shifts like a hurst, flawessly in the short throw linkage holes.
Go for the new one and never have to get under your car again.
http://www.volvette.com/SH005.html
They are a pleasure to deal wth as well.
Go for it!!
PS - The hurst does not have the reverse lock out like the Muncie Shifter does.
Go for it!!
