Converting '64 to '67 Dual Master Cylinder
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
If I use the '67 dual MC on my power brake '64, where would I have to go from 3/16" to 1/4" lines? Of course, I just finished installing new brake lines on the frame last week. I've read that the rear distribution block would need to be changed, indicating the line from the mc would be 1/4". How much and/or where would I HAVE to use 1/4" lines? Fortunately, I've still got the bare frame in the garage, so I figure now would be the time to spend MORE money preparing for the conversion. Would the change effect the size of the front brake lines?
Thanks for any help.
Dave
Dave
Dave
Dave
Received 1,857 Likes
If you're staying with drum brakes, you don't want to use a '67 Corvette master cylinder - it's for disc brakes, and neither outlet has RPV's (residual pressure valves), which are required for drum brakes to avoid excessive pedal travel. You need a dual master cylinder for a drum/drum brake car (like a '67 Camaro, Nova, etc.).
Is the bolt pattern(Camaro, Nova) the same for a 64' vette?
Found casting # 5452310 for drum brakes?
Jim
Thanks for the info guys. As I'm staying with drums (for the time-being), I'll use the Camero MC.
Dave
Dave
Dave,
I am doing the same swap. I've read these posts and am glad you asked the question.
Do you know if the '67 Camaro dual MC has the proportioning valve internal to the master cylinder? I'm trying to figure out all of the pieces/parts that go with this operation and I'm not sure what all I need beyond just the '67 Camaro dual mc.
Please let me know what you've learned.
Thanks,
Steve
678-481-1087
Thanks,
Steve
678-481-1087
For that conversion you want a '67 Camaro or Nova DRUM/DRUM master cylinder (so it has the residual pressure valves in the outlets behind the tube seats).
I installed a '67 MC/booster on my '63 11 years ago with no proportioning valve and have had great luck with it. The pedal is high and hard as a rock, stops like a million bucks, no leakage from the wheel cylinders or anything regarding the lack of a residual check valve. I did open a front and rear bleeder on installation and verify one circuit of the brakes was still functional.
The front outlet of the MC has a reducing adapter and feeds the front wheels. The rear outlet of the MC goes directly to the rear wheels, I probably have good pictures if you need them. I did have to notch the hood slightly to clear the MC, I did this by grafting in a small section of a '67 hood which has the appropriate clearance designed into it.
My car stops like it has 4 wheel disc brakes- really excellent! I've had other '63 owners drive it and they are amazed with how the brakes feel. IIRC, the brake components are all Muskegon brake- shoes, cylinders, hoses, etc, all 12+ years old, but under 15K miles. I don't run the car hard enough to need disc brakes- just cruise to shows and etc. I feel disc brakes would only be needed in a road racing application or other hard use. Most cruisers don't need them.
Good Luck!
Good Luck!
If you're not using a booster, you won't have to modify your hood. The booster added length to the master cylinder, and then they tilted it up, probably to clear the valve cover.
My '66 with booster. Standard master cylinder is not tilted up.
Regarding the parts needed for the '64 single cylinder master cylinder swap, I am going to answer my own question with info that I learned from a brake tech at YearOne.
1) No residual pressure valve is needed as long as the brake cyliners are lower than the brake master cyliner (they certainly are).
2) No proportioning valve is necessary. The "proportioning" is done by adjusting the rear brakes to "come in" (pads make contact with drums) before the fronts.
So, to do the swap, all you need is the '67 Camaro (for instance) drum/drum master cylinder. Run the front cylinder line to a 2-way splitter that goes to the front brakes, run the rear cylinder to the line that goes to the rear (that is already split once is gets to the back of the car), bleed the brakes and adjust the brake cylinders and you're done.
ccsbinc.com makes a kit that includes a MC that works, along with all new lines and stuff that they even say is not necessary for $290. The link is below.
http://www.cssbinc.com/1963-64corvet...brakecars.aspx
But the '67 MC with the hookups described above should be all that is necessary according to one smart guy (an ACE brake technician as well as an old car mechanic and parts guy).
Thanks for everybody's help.
1) No, you still may need residual valve(s). If they are built into the M/C (most probably), great. If not, you end up giving the brakes an initial pump to pressurize the wheel cylinders before getting to the real braking action. When I used a '70s Corvette M/C on my '64 (with rear drums), the M/C had a 2# residual valve built in (as they do), and it was not enough for the drums and I always had to give the brakes a pump before they would work well.
2) While no proportioning valve may be necessary, it is the physical size of the brakes that do the "proportioning" and not the adjustment of the pads. If memory serves, the rears are 2-1/2" and the fronts are 3" providing more stopping power in the front. But while you are at it, you may want to add a proportioning valve anyway to better balance (fine tune) the system.
Steve,
These guys gave you much more and better information than I could. Thank you guys for your technical expertise.
Dave
Dave
There are no master cylinders with internal proportioning valves, and Corvettes prior to '77 don't use external proportioning valves (except J-56).
Thanks in advance,
Leo
