66 Horn Relay Photos?
Old 09-29-2009, 10:47 AM
mikem350
mikem350's Avatar
Default 66 Horn Relay Photos?
In the process of attaching my wiring at the horn relay and need to know which side of the radiator support it goes? Bubba was there before me...
Also there is only one red hot wire there w/the ammeter sense lead attached. I assume this is correct for a '66, and this wire runs to a multi connection inside the wire harness? Thats what the diagram hints at anyway.
Photos appreciated,
TIA, Mike
Old 09-29-2009, 10:49 AM
wilbur
wilbur's Avatar
inside drivers side
Old 09-29-2009, 10:58 AM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
This is a '67, but the mounting is the same as a '66. The only wires on the screw terminals on a '66 are the red power feed and the black/white sense wire for the battery gauge.
Old 09-29-2009, 11:26 AM
mikem350
mikem350's Avatar
Thanks guys...and the red wire runs to a multi splice inside the harness?
Old 09-29-2009, 11:46 AM
JohnZ
JohnZ's Avatar
Yup - that splice then feeds the voltage regulator, alternator hot terminal, and the 12-ga. red feed wire to the bulkhead connector.
To 66 Horn Relay Photos?
Quick Reply: 66 Horn Relay Photos?
