Timing Chain Lubrication Question
How does the timing chain get it's liubrication? I ask because some suggest drilling a small hole in each of the 2 oil gallery plugs in front of the chain for oiling purposes. I know Chevrolet sells these plugs that are pre-drilled as well for this purpose. Is this necessary? I'm running a gear drive in my BB instead of the chain and wonder how it gets lubricated and does it get enough oil/lube? Thanks!
I would highly recomend some additional oiling for a big block, especially with a gear drive. I drill a single .030 hole in one of the oil galley plugs, that will give the gears some oil all the time. Otherwise, the only way you get oil up there is sloshing from the pan or the lifter valley, and a little from the front cam bearing. This is a pretty common problem and fix!
