1958 block pad stamping suffix
I looked at a block in florida that had the correct casting number for a 58 corvette 3737739 and the date by the distribuitor was E98, but the problem was the front pad stamp was F513P. The F is for flint and the 5 is may and 13 is for the 13th day.......but what the heck is P. I thought that the suffix should have two letters. Does anyone know what the single letter P is. Thanks for any help.
I don't think its a Corvette block...it should have a two letter suffix per: http://corvette-world.com/corvette_1...tion_codes.php. That casting number was used in trucks and passenger cars: http://www.thedirtforum.com/castings.htm and I'm betting that's what you have...
I would also run the question by the judge asking how many points are deducted for a factory correct replacement engine. I believe it's not too many points to be concerned with. Good luck, and let us know what your findings are!
rustylugnuts
Also trucks & full size vehicles engine in those years were from Tonawanda not Flint!
rustylugnuts
'Factory replacement engines' don't get special treatment during NCRS judging.
rustylugnuts
Received 1,856 Likes
Nope, not hardly. Flint and Tonawanda each built 5500+ engines per day; All of the Tonawanda engines went into passenger cars and trucks, and so did the engines from Flint, except for the 50-60 per day that Flint sent to St. Louis for Corvettes.
rustylugnuts
So even if this is relevant, the fact still remains that the passenger car & truck engines regardless where they came from, had motor mount holes drilled & tapped on the sides of the block. When this particular engine did not, and that alone indicates the engine in question can "only" be used on a Corvette.
rustylugnuts
rustylugnuts
Received 1,283 Likes
I have a friend with an NOS 58 long block assembly (739 casting if I recall). He bought it over the counter in 58.
The front pad is completely blank, but has real nice broach marks.
The interesting thing is that the heads (770 heads I think) are drilled and tapped on the ends like the later model heads. This was for mounting of the air ride suspension system compressor that was an available option in 58.
All 739 blocks had the three bosses and tapped holes on each side for the new motormounts, although not all passenger car and truck applications used them in '58 - many still used the two 3/8"-16 holes on each side of the front of the block for the cushion brackets that were used for all '55-'57 applications.
Thanks, rustylugnuts
