Does anyone have a pic of....
..........the rear side pipe mount? Preferably on a body off frame.
Any pics appreciated.
Thanks, Dave
Thanks, Dave
Moderator
63's and 64's did not come stock with side pipes so there will be no 'keyhole' attach point. Two things you can do; 1) cut the keyhole in the bottom of the frame from later vette drawings or 2) install your side pipes using a jack or wood to put the rear of the side pipe into position, mark and then weld a grade 8 bolt to the bottom of the frame. I did the latter and my side pipes have been on for years with no issues. You can always cut the bolt off and grind the weld off if you ever want to go back stock.
Thanks Ken. No rush on this. I know it's kinda wet over on your side of the hill. I shoveled some this morning and there's more on the way.
Is the slot centered in bottom of the frame rail?
Distance from the aft end of the frame rail to the aft end of the key slot?
Length of the key slot?
I like the idea of welding in the bolt per Master Dave and will look at that possibility.
Yeah, that material used in the frame is some real American steel. The few holes that I've had to drill are a bear without a new carbide drill (or maybe it's just that I'm getting old and weak)
I might also run a carriage bolt. I can cut a slot in the bottom then drop the bolt it through one of the slots in the side of the frame. I'll have a look/see if it's possible.
Picked it up last Thursday. You been on vacation?
http://forums.corvetteforum.com/c1-a...aint-shop.html
Holy cow...how did I miss that post??? Looking good Dave, should only take you another couple of weeks to get it running, right? Heck, you'll probably have yours out before mines done...man, parts take a long time to get...still receiving parts I ordered in December, and all are not in...what's the old expression..."all good things come to those who wait..." we must be getting good things cuz the wait is a killer...good thing the weather is cooperating by keeping us indoors...if the sun was shining the the roads were dry...I'd really be chomping at the bit...
Dave, the main large round hole is 3" forward of the rear frame centered on the angled part of the frame. You can see the frame cross member and the rear of the hole almost is in line with the cross member. The hole with slot from end to end is 3" long so you have room for play/adjustment on length of the sidepipe. The hole is about 7/8" diameter and the slot is 1/2" wide. Remember, this is located on the angled part of the rail, not the bottom or side.
Send me your email address and I have the 2 pages of the assembly instructions for a 65 side exhaust from my assembly manual.
