Wire Wound Resistors on back of Voltage Regulator
Anyone know where I might find the resistors that are on the back of the delco remy voltage regulators (1119001) for a 58-60...do they still make them?
If not, anyone know what the ohm value is and what kind of wire they used?
Thanks!
Thanks!
If you are talking about the one on the right in this picture....good luck...I don't know where you would get one.
Probably be easier to find an old junk VR and cannibalize the parts that you need. The VR does not have to be a 9001 series.
PS The horizontal resistor (broken one in pic} is 24 ohms and the vertical one is 1.2 ohms.
