C2 Alignment Problems - Upper Control Off-Set Kit
He is using a high tech laser alignment system and ensured me it is extremely accurate.
It used to have minimum shims and the Vette went down the road dead straight w/o pulling before the new front end was installed.
He also complained that the right rear suspension needed additional shims.
He suggested installing offset upper control arms shafts.
http://www.ecklers.com/product.asp?p...8&dept_id=1790
Do I need two or just on the side that needs the extra shims?
I doubled check and made sure I did not have the upper control are reversed.
Can anyone provide any time saving and safety hints to make this job easier?
Does the spring have to be removed again?
What a Disappointment / nightmare!
Thanks in advance for helping!
Andy
Dennis
I have the VBP offset upper control arms on my car.
My alignment guy uses a Hunter machine that is the laser type also. He was able to obtain factory correct settings with the stock uppers but I didn't want stock settings. They could not be achieved with the stock uppers but by changing to the offset uppers we were able to make it.
You don't have to remove the spring to change the upper arm out.
I don't know if they sell the offset arms individually but you would want to replace as a pair anyway. They are visually quite different from your stock arms.
Rich
What does the installation of the offset upper control job involve?
1. Remove both front wheels – can the calipers remain on?
2. Does the shock have to be removed?
3. Jack the lower control arm & remove the upper (should a chain be used to make this is safer operation? I’m concerned that the car will lift up and not compress the new stock BB spring.
4. Is the removal and installation of the offset arms a big deal with the urethane bushing?
5. Can the urethane bushing be used again or will new ones have to be installed? The kit comes with rubber bushing but I would like to stick with the urethane.
Any information to make this job easier will be much appreciated!
Thanks again!
Andy
The offset shafts should be available from your FLAPS.
Rich
Here are the alignment specs for my 1966 Big Block.
Primary Angles
Front Caster Left Init -0.20 Spec 1.25 - 3.25 Final 0.52
Caster Right Init 2.41 Spec 1.25 - 3.25 Final 2.59
Camber Left Init 0.16 Spec 0.25 - 1.25 Final 0.62
Camber Right Init 0.03 Spec 0.25 - 1.25 Final 0.21
Toe Left Init -0.11 Spec 0.09 -0.15 Final 0.12
Toe Right Init -0.29 Spec 0.09 - 0.15 Final 0.11
Total Init -0.41 Spec 0.19 -0.31 Final 0.23
Rear Camber Left Init -3.04 Spec -0.05 - 0.5 Final 0.14
Camber Right Init -0.55 Spec -0.05 - 0.5 Final 0.07
Toe Left Init -0.17 Spec 0 - 0.06 Final 0.03
Toe right Init -0.19 Spec 0 - 0.06 Final 0.23
Total Init 0.02 Spec 0 -0.12 Final 0.26
Thrust Angle Init -0.37 Final -0.2
I just received the offset shafts and want to make sure I install them correctly. Does the offset go towards the engine? Another words - I want to move the upper control arm towards the engine!
Thanks to everyone for your help!
Andy
http://forums.corvetteforum.com/c1-a...ent-specs.html
However, as sanity check, I want to make sure the upper right control arm in on the right side of the Vette.
How can I definitively determine the difference between the upper left & upper right control?
Thanks!
Andy
Thanks!
Andy
He is using a Hunter Engineering, laser alignment system, and ensured me it is extremely accurate.
He also complained that the right rear suspension needed additional shims. This was serviced by a mechanic many years ago & he may have copied the shim placemtn form the other side & now it is creating problems.
I recently installed Moog offset control arms which after an alignment should take care of this issue.
I’m currently working on removing the rear trailing arm bolts & plan to install new bolts, nuts & slotted shims.
Here are my questions:
1. Can anyone provide any time saving and safety hints to make this job easier?
2. Reviewing the spec below can anyone tell me how many shims I have to add or subtract to get the RR trailing arm in spec?
The alignment shop will not work on the car unless I replace the bolts & shims.
I want to get it as close as possible so he does not have to adjust the Rear Toe.
Primary Angles
Rear Camber Right Init -0.55 Spec -0.05 - 0.5 Final 0.07
Thanks!
Andy
To get increased caster (3.5) in my 66, I replaced the factory bolts with longer (grade8) bolts that allowed a spacer to be placed at the base of the shims. Nothing else had to be removed.
1. What is the thickness of the Right Rear shim that has to be added or subtracted from the inner or outside trailing arm to meet GM spec?
2. I only want to remove & replace the trail arm bolts to get the rear suspension w/ in spec.
At this time I do not plan to remove the entire trailing arm unless I have to.
Is it safe to remove the training arm bolt w/ 4 jack stands supporting the frame & nothing supporting the trailing arm?
I'm very concerned about the rear spring pressure & getting a new bolt back in place w/ the rest of the trailing arm still attached.
Thanks!
Andy
