Ignition Coil question
Old 03-20-2010, 01:07 PM
Subfixer
POSSE ZR-1 Driver
Support Corvetteforum!
Subfixer's Avatar
Default Ignition Coil question
Car: 64 327/365 (L76)
I am looking for a replacement coil that will fit under the original shielding without crushing the primary coil lead to the distributor. Most FLAPS replacement coils are too tall.
There are a number of Corvette parts vendors selling one coil that is labeled for use in 63-74 model years, and other vendors that have different coils for specific years and horsepower ratings.
I would rather not spend $90 for a replacement coil, but I don't want to spend $40 for a coil that won't fit either.
Any ideas out there?
Thanks.
Old 03-20-2010, 01:22 PM
JohnZ
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
On a '64 L-76, the correct coil depends when your car was built. Cars built prior to January used the 1115091 coil with the 0.3 ohm ballast resistor, and cars built from January on used the 1115087 coil with the 1.8 ohm ballast resistor.
Old 03-20-2010, 01:24 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
The Echlin coil from NAPA used to be same size as Delco. Don't know if it still is.
How about 90* terminals on your coil wire instead of straight?
Old 03-20-2010, 01:55 PM
Subfixer
POSSE ZR-1 Driver
Subfixer's Avatar
Thanks John.
Mike, I thought about that also. I need a new coil, so I figured I'd try to get one that fits correctly.
Old 03-20-2010, 02:06 PM
Donald #31176
Donald #31176's Avatar
Standard Motor Parts replacement equivalent is UC12 coil. Dont know if there are shielding fitment issues.
Old 03-20-2010, 02:24 PM
toddalin
toddalin's Avatar
Received 1,152 Likes on 484 Posts
I've got one that will fit. It came off my '64 and I have the shielding. It is an original Delco-Remy. The case is marked 293 and the next line is marked B-R or maybe 8-R. It worked fine when I pulled it off and the resistance across the terminals reads ~2.1 ohms.
I don't know if this was original to the car or a GM replacement. Maybe someone knows how to interpret the numbers and we can go from there.
Old 03-20-2010, 02:52 PM
JohnZ
JohnZ's Avatar
I have a UC-12 as the shelf backup for the 202 on my '67; no height issues, but it's slightly larger in diameter (still fits in the clamp).
Old 03-20-2010, 03:04 PM
Subfixer
POSSE ZR-1 Driver
Subfixer's Avatar
When it's handy, if you could measure the height, that would be helpful.
Thanks.
Old 03-20-2010, 04:48 PM
toddalin
toddalin's Avatar
Thanks.
Top of the post to bottom of can is 6".
Old 03-20-2010, 05:11 PM
Subfixer
POSSE ZR-1 Driver
Subfixer's Avatar
Excellent, thanks!
To Ignition Coil question
Quick Reply: Ignition Coil question
