Sidepipe cover insulation, do ya really need it?
Old 04-03-2010, 06:28 PM
6T7L71CPE
6T7L71CPE's Avatar
Default Sidepipe cover insulation, do ya really need it?
I just reinstalled my OEM side pipes with new front pipes. The "Driver" quality, or maybe "Rat Rod" quality, cover insulation has seen better days. Is anyone running without the FG insulation? There should be enough space for them to stay cool. Thanks
Old 04-03-2010, 08:14 PM
Bill Irwin
Bill Irwin's Avatar
That's a very good ?. No doubt the shield will get a bit warmer, should be no factor.
What might be, is more heat in the cockpit. Sorry I don't have a definitive answer. Bill
Old 04-03-2010, 08:44 PM
nassau66427
nassau66427's Avatar
Location: going faster miles an hour...with the radio on in browns mills new jersey
Before I switched to sidemounts, I ran sipepipes for years without the insulators - no problem.
The covers didn't get all that hot.
Old 04-04-2010, 12:14 AM
silverslashstreak
silverslashstreak's Avatar
I removed my Insulators 10 years ago when I put in 3.5 inch glass packs. My wife and I have driven thousands of miles like that with no problem and I have grandkids with me all the time with no problem. They do get a little hotter but have never burned anyone
jeff
Old 04-04-2010, 12:41 PM
vt65
vt65's Avatar
my last '65 had side pipes and no insulators...no problem but was only running stock 2" pipe, could touch them and didn't get burned
Old 04-04-2010, 12:47 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
My 67 never had them on it, but only got a little warm not that bad. But for sure more than the 65 I have now with them on the car. YOU WILL BE FINE HERE MAN...
Old 04-04-2010, 12:58 PM
vark_wso
vark_wso's Avatar
If you are using carbon steel (plain or aluminized) or the 'straight chrome' magnetic stainless pipes, they exhibit 3-4X higher thermal conductivity than the non-magnetic (usually type 304) stainless products. Thus, they 'sink off' the exhaust heat pretty well and should cause you little or no difficulty. If, on the other hand, you have side exhaust in the non-magnetic grades, the pipes themselves retain the exhaust gas heat much longer. It's probably not a big deal or hazard -- just wouldn't expect the aluminum shield to be as cool to touch as soon after a run.
Old 04-04-2010, 01:30 PM
silverslashstreak
Another side benifit, I feel that by letting the heat out of the openings in the covers stops a lot of heat soak to the frame and bidcage resulting in cooler cabin temp on long runs
Jeff
Old 04-04-2010, 05:58 PM
6T7L71CPE
6T7L71CPE's Avatar
Thanks for the replies, I'm going for it! They are OEM pipes so I assume plain carbon steel.
To Sidepipe cover insulation, do ya really need it?
Quick Reply: Sidepipe cover insulation, do ya really need it?
