•► ► TOTALLY FREE DRIVETRAIN INSPECTION - at Corvettes of Westchester - FREE ◄ ◄•
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Hey guys...The weather is getting better up here in the Northeast and SPRING is just around the corner...
Very soon every Vette owner in the area is gonna pop the garage open and fire her up!
But wait ! My C-2/3 is probably between 30 and 40 years old this year....
Let's face it....The independent rear end/suspension is the worst part of the whole car to work on...
and Likely, the last thing you wanna think about....
When you view your Vette from the rear...Do the rear wheels tilt in at the top?
Does it have a hard ride and clunk a lot or make any unexplained noises while you cruise around....?
Does your Vette steer more from the rear than the front????
Are Hondas with fat tailpipes faster than your Classic Vette???
Is your totally dead positraction going clunk...clunk...clunk...as you make turns????
Here's the deal....The most popular operation performed on C2's & C3's in our shop
(with the exception of brakes) is Rear End Service.....
We REBUILD ALL CALIPERS ON SITE using the best parts available
AND WE GUARANTEE THEM NOT TO LEAK AS LONG AS YOU OWN THEM
when installed as a set of four (4) with a new master cyl.
Ring and pinion upgrades. (ever wish you had 3.73's instead of 2.73's...)
Rear diff bearing, seal, and positraction overhauls.
Universal joint service.
In house trail arm rebuilding.
Parking brake system repair.
Brake system overhauls.
Fiberglass rear springs installed.
KYB Gas-A-Just shocks installed.
Energy Suspension Poly Graphite suspension bushings installed.
And the BEST 4 WHEEL CORVETTE LASER ALIGNMENT available when we're done!
TOTAL REAR DIFF/SUSPENSION Service by a shop that has rebuilt more rear vette suspensions
than any other shop this side of the country. Experienced techs...All of the
original factory tools on hand...and all of the necessary parts in stock
ALL OF THE TIME.
Come to Corvettes of Westchester for your TOTALLY FREE undercar inspection and estimate.....
We'll put your vette up and point out whatever service your vehicle needs and explain all of your
options on the spot...The service takes about 20 mins....You will personally see first hand
Exactly what your car ACTUALLY needs...
Remember...the rear suspension of any Vette from 63 to 82 is the most neglected part of the whole car...
Those rear diffs do not have drain holes for service....That nasty gear oil from the 60's and 70's is likely
still in there today...Not Good...and those rubber bushings...GONE!
....and those old delco or sears shocks....They were junk when they were new!
Treat yourself and your Vette to a TOTALLY FREE UNDERCAR INSPECTION with no obligation at all...
You and your Vette will love each other all over again!
Call for an appointment....
Thanks,
Chuck CoW
