66 BB, would you know the length on this captive belt ?
For a 66 bb, I would like to know if anybody knows the length of the belt that is closest to the block, it runs the wtr pmp and crank, no adjustment. The car has ps...thats it. Both pulleys are 2 groove. Lower pulley is 6 and 3/4 and the wp pulley is 7 inches wide. I believe all the pulleys are correct. Got the 2 other belts after many trips to the FLAPS, cant nail this one down though. Thank you in advance.
My car doesn't have power steering but I don't think that makes any difference. Here are the numbers off of my belt.
GM9433722 FC 440 X 35.000 DAYCO 42-3529
Just use the DAYCO number and either cross reference or find a LAPS that sells DAYCO.
Hope this helps.
Steve
Thank you very much ! I will try tomorrow.
The Corvette Parts Book calls for GM part # 3837810, at 3/8" x 34 3/8". This is the belt that runs from the water pump pulley to the crank pulley, in the groove closest to the block.
Hey......thanks for all the help, I took the part numbers with me to napa this morning and I finally got what I feel to be the right belt on. was not fun to install but it appairs to be a great fit. Hope this can help others. Thank you again !
I found it easier to put the belt in the water pump pulley groove as the pulley was being installed. As opposed to trying to get the belt on with the pulley in place.
Hey thanks, yes I know the pulley you have, its probably the one sitting on my garage floor that I took off prior to adding the pwr strg. Thats how I got this belt on, with the wp pulley off.... still a lil struggle but it finally popped into position.
