NOS 327 crate short block - photos
I finally got this engine out of my trunk & on a stand. Here are the photos
http://59chevypickup.webs.com/apps/p...lbumid=9459149
So what kind of cam is this? It cam an orange stripe, the #15 stamped into it, a cast "16", a cast diamond, & a cast "GM4"
Thanks!!!
Thanks!!!
nice to see another , this year i found same motor never started at all stock pistons but there was no cam in my motor .forged small journal crank. the 512 blocks will take spin on oil filter, your block has the 10 marking on it as well .mine I balanced it and installed a 151 L79 camshaft ,my motor did not have the high compression pistons , we used 291 double hump heads and it now sits in a 61 vette where did you find your 512 block. mine was from jim glass corvettes,
i won it on ebay last week. It just north of boston in a carpet warehouse. He was clearing out his vette stuff...
Received 1,857 Likes
There should be a 4-digit raised casting number somewhere between the lobes on that cam that will identify it, unless they ground it off when they stamped the "15" on it. Have never seen a GM cam ground and stamped like that one.
John did they make 327 blocks with the 010 and this one even is a 020. I believe high tin/nickel content? I guess what I'm asking is how can you look and tell a 327 from a 350. I know enough about the 350's I've built but never really touched a 327.
Depends when it was cast - what's the casting date on the pass. side rear block flange?
More pics
On the end of the cam, there's a "38" written in orange with a light blue paint dot
This might be a 153 or 158.
This stamp is opposite the diamond mark
It also has orange stripe on 1 end & yellow or lt green on the other
The only cast # on it is a "16". On either side is a screw head impression. Next to the 16 is a small white paint dot
More block pics here
Is has a strange oil filter adapter...no threads
Good luck... GUSTO
Stuff that cam back in the motor and get a mag base dial indicator and rotate the cam and tell us the lobe lift on intake and exhaust, that should ID the cam pretty accurately.
It is most likely an L46 Hyd cam, but could be something else.
Doug
Doug
Received 1,843 Likes
If that is a CE 327 engine, I'd think it would have a L 79 cam in it, not L 82.
I measured 0.298" on all of them
thanks man, I did get a killer deal. I just have to change directions on my pickup build because of this 327. I was planning on a 455 Olds, but this engine is almost ready to drop in, plus it will rev a lot higher, hehe. I'll save the 455 for a covertable '68 Cutlass
That would point to a L-79 Hyd 151 cam (most likely) or 346 mech cam.
What separates them is duration.
At .010" lift (measured at top of a lifter), the duration on the mech cam is .283/.283,
The L79 cam, at .005" lift (at lifter top) is .284/.284".
Those are very close numbers, but since they are measure at different left heights, you should be able to tell them apart, as the L79 cam will have significant shorter duration at .010" lift.
You have to measure off a lifter to use these numbers.
Doug
Doug
The solid lifter cams for first gen small blocks was ID'd by a blue paint swatch. I don't remember what color the 151 had on it. Besides, they didn't make any CE SB's blocks with solid lifters.
If you look at the same area on similar vintage Tonawanda small block you should find the numbers 014 for the Tonawanda 3970014 350 block, an 024 for the 3970024 Tonawanda 307, and probably a 511 for the Tonawanda 3951511 400 block.
This myth of the 010/020 meaning "high nickle" block just won't die.
The 010 and 020 have nothing to do with nickle content. They represent the last three digits of the casting number of blocks that use the same front mould pattern.ie, 3970010 and 3970020, both of which are Saginaw castings, the 010 being a 350 and the 020 being the 307 block. Note also the 509 just under the 010 and 020. That refers to the 3951509 which was a Saginaw 400 block using the same front casting pattern.
