C1 Steeroids installation with many photos
#41
Premium Supporting Vendor
I just updated that last post in the installation. It seems that the video link stopped working for some reason.
__________________
www.SpeedDirect.com
Corvette Forum Members get 10% off with code: CF10
Steeroids rack & pinion conversion kit for '53-'82 Corvettes
Shark Bite Suspension Front & Rear Coil-Overs, Aluminum A-Arms & Diff Covers, Stage Kits
Rod Links Spherical rod end clutch linkage for '65-'82 Corvettes
www.SpeedDirect.com
#43
St. Jude Donor '07
yes if a purist is interested in the car and wants the original steering system, no if an interested person wants a better, tighter, more responsive steering system.
Bill
#44
Handling issue
Trying to revive this old thread based on a few on the comments/concerns.
I installed the power R/P and have been fighting with a good setup. In order to get 3-4 deg of caster I had to stack (4) shims between the frame and front end. This created a serious issue with front end geometry and apparently I am beyond the adjustment window on the tie rods. My toe is all over the place- goes from positive to negative from unloaded to me to me+passenger.
I think the issue is that the R/P is mounted to the frame instead of the front suspension. The dilemma is that there is no way for me (on my car) to get more than 2 deg of caster with only one or two shims- I did udjust the upper arms aft as far as possible...
Looking to see if any of the experts has any ideas. I have emailed Speeddirect to ask for help as well. I've already missed one trip due to this thing, so if I can't find a solution this setup will be for sale and Jim Meyer to the rescue...
Any input appreciated- Mark
#45
installing steeroids with power steering and also front disk brakes conversion kit.
I am installing steeroids with power steering and also front disk brakes conversion kit on my 1959 corvette. My question is which should i do first or does it make a difference?
#46
The disc brake kit includes roller bearings, so it would probably be best to have those installed before driving it with R&P. But if you’re installing both at the same time, I don’t think it matters which you do first. When I did mine I installed the brakes first, then drove it for a couple of months before installing Steeroids.
#47
Received 1,962 Likes
i had that problem when i first installed my R&P IFS, it was SCARY....
they now make valves and flow adapters to 'dumb-down' the GM power steering pump to make the steering heavier feeling and therefore give it more road feel.
makes the steering feel less sensitive to change even though it doesn't affect the ratio; just have to put more effort into the change.
Bill
Bill
I installed a Steeroids R & P Power Steering system in my '66 and used this pressure control valve in the pump - works great - no "twitchiness" in my steering!
https://www.detroitspeed.com/power-s...l-valve-091401
Tom
