Storing/Hanging C2 Hardtop
I've researched prior threads and am still looking for a creative way to get my hardtop out of the way. I can either hang it on the wall, up high, or hand it on the ceiling. Anyone have a method that works well?
Greg
Greg
Wall hang it
Get a couple of lag-hooks and screw them into studs 32" horizontally apart. About 4-5 feet up the wall.
Get a length of smooth rod (I used 1/4" dia.") and cut it long enough to go through the side attachment plate holes with 1-2" extending on each end.
Drill holes on each end to accept hitch pin clips.
Install the rod onto the top and you can just lift it up and hang the rod on your lag hooks. The header will rest on the wall surface so you may want use a piece of foam to prevent flattening of the rubber. Throw a sheet over it and you're good to go.
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
Sounds like an easy, quick storage solution...and much cheaper than buying a ceiling rack.
Received 1,856 Likes
Or buy one of those top hoists for cheap (like $29) and some nylon ratchet straps for extra security and hang it from the ceiling ready to drop on the car. A flat steel rod across the bottom of the top keeps it from distorting over time. Some strategically placed pieces of wooden paint stirrer sticks keeps the straps of the weatherstripping.
Here is my C1 top...
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Gee Frankie you really don't trust that center strap do you, ha ha. Better safe than sorry. I like that system, because it makes it an easy one man procedure to install and remove.
Received 6,519 Likes
C2 of Year Finalist (track prepared) 2019
Perfect! That's exactually what I was looking for. Thanks everone
Greg
Greg
