C2 headlight motors
C2 headlight motors
Has anyone on the forum rebuilt their own headlight motors and was it much of a job?? Also, does anyone have a recommendation on who does a good job at rebuilding them and what their pricing and turnaround time was. Thanks in advance for your answers and recommendations!
Howdy,
What is your definition of rebuild? For example, the ones in myh 65 were not working, so I followed the instructions from Alann Boatright found on BarryK's web site:
http://www.lbfun.com/warehouse/tech_...%20Rebuild.pdf
and removed my motors. I disassembled them, cleaned everything up, replaced the old hard grease with new grease, installed, and they worked fine.
Now if yours are messed up, need new windings, etc. then I can't offer any personal experience.
Jeff
Jeff
1960 (11-14-2021)
Howdy,
Jeff
Jeff
I also followed those instructions, worked great.
1960 (11-14-2021)
What sort of problems are you having that's making you ask about rebuilding the headlight motors? Are they slow or intermittently working? If so, while it could be the motors, it also could be anything connected to them starting with the dash switch, poor grounding, deteriorated wiring harness, etc. If the motors are the actual cause, it might be the potmetal gear that's given up the ghost or lack of lubrication or maybe the brushes are worn down.
They are pretty easy to take apart and most times if there is something amiss, you'll find it by the time you get down to the brush plate. If not...then it's probably time to send it out.
On my 65 I had one motor making some god-awful sounds as it was trying to raise the pod. Not so bad sounding on the way down, which obviously has less stress on the motor. In my case, someone had been in there before me and I found the lower amature 'bushing' to be moving around, hence the 'growling' sound it made since it allowed the armature to move around. I had to use a Dremel Tool to cut into the welds in order to separate the lower plate and replace the retainer and bushing with donor parts out of a power window motor. If yours are just moving slow, check out everything else first and then tear into the motors. It's not hard to do.
Mike T.
Mike T.
1960 (11-14-2021)
Motor Switch
If your motors are not opening... first disconnect the switch located
under the dash. Take is apart and clean all contacts. Put it back
together and install. That may be your problem...
I too pulled my motors and cleaned, re-greased, and reassembled.
Its an easy job. I also took out the motors with the hood open and
using a mirror and flashlight I could locate the screw that holds the
motor in place and pull them out. Took 10 minutes for the first motor
and 2 for the second. Otherwise I hear you have to pull the front
bumpers, front grille, and then access the motors from the bottom
on your back.
First clean and re-install the switch ! I bet that's the issue...
on your back.
1960 (11-14-2021)
C2 of Year Finalist (appearance mods) 2019
Rather than taking all that apart, I just removed my hood and then it was easy to get to the motors. Make sure you mark your hood first with tape around the hinge, so you can put it back exactly like you found it.
1960 (11-14-2021)
Howdy,
Jeff
Jeff
1960 (11-14-2021)
On the topic of C2 headlights, the engine and battery were removed.
The wiring un-plugged.
Is there any way to rotate without power?
Like some mechanical release?
The painter may need to turn or remove to paint properly.
Maybe if removed, they need not rotate?
It is the wheel on the left of this motor
1960 (11-14-2021)
Mike T.
Mike T.
1960 (11-14-2021)
Prescott Soon...We Hope
Hi Steve, PM sent. So, was the car show held up at Bucky's Casino?
How was the turnout?
That is odd that the thumbwheel is MIA but not totally surprising that some so-called mechanic figured it was not needed.
Once you get the motor(s) free of the headlight pods, you'll see they come apart fairly easily and it's unlikely you'll encounter a problem like I had with my one motor.
Mike T.
Mike T.
Mike T.
Mike T.
Hi Steve,
There's a very good chance your headlight pod issues are being caused by something minor and a good clean-out and lube of the motors along with verifying electrical connections, power/ground, will do the trick.
Looking forward to meeting you guys at the banquet too and finally being in town for the Corvete Show on Saturday. Sounds like you're going to reach that 250 Vette ceiling after all.
See you then.
See you then.
6th Gear
Wish I had seen this post before, am working on a pair of 67 headlight motors. Removed 1 from the car yesterday, (neither has ever been out before) the thumb wheel would not turn. These motors were running 6 months ago. Took what I would call the motor off the "transmission", and the armature turned very hard with the thumb wheel. Now that I have seen these instructions, will remove the armature, but am wondering if the bearing might be seized? Do these bearing commonly seize up?
I used the instructions, they are awesome. The previous owner had bought a repro motor and it failed already. Luckily he still had the original. I rebuilt both originals and used the new gear out of the repro in one of them, they both glide up and down perfectly now !
I really have to credit the author of that article, what a great contribution to the community, the instructions are perfect and can save a lot of time and money for others.
1960 (11-14-2021)
I soak the bearing in penetrating lube to loosen the bearing. I then hone the bearing and clean and polish the armature.
Cut the crimp welds and remove the end plate.
Now you are ready to weld the new retainer & spring. Available at Long Island Corvette Supply
Weld the end plate back on and reassemble.
There you have it. Like new motors.
6th Gear
Just got both motors back on, and they work great. The information here made it so easy, nothing to be intimidated about when you can see it laid out in front of you first.
On both motors, the bearing in the back end of the motor were seized with crud. Cleaned everything up and re-lubed it all. Should be good for another 10-20 years anyway. Thanks for the help.
1960 (11-14-2021)
