Where to send Glovebox Door for Restoration?
Old 09-27-2010, 12:31 AM
Corbrastang
Corbrastang's Avatar
Default Where to send Glovebox Door for Restoration?
I did a search, but did not come up with much.
I just need a new insert, but i need it to be NCRS correct-rivets, insert, etc. I see that Paragon and a few others offer the service, but i like to support the smaller guys.
Corbrastang is offline
Old 09-27-2010, 12:58 AM
gbvette62
gbvette62's Avatar
Received 2,016 Likes on 1,308 Posts
They're not that difficult to do, just a biy of a PIA. The kits come with small allen head screws that you hit the center with a drill bit with after assembling, it really looks pretty much like a rivet again.
Corvette Specialties (formerly) of Maryland does them. They do a great job and are a Furom Sponsor. Unfortunetely, they are moving from Maryland to somewhere on the left coast currently, and have temporarily stopped taking restoration work, until their move is completed.
gbvette62 is offline
Old 09-27-2010, 08:37 AM
nassau66427
nassau66427's Avatar
Location: going faster miles an hour...with the radio on in browns mills new jersey
Do it yourself from the front. No need to mess with drilling and little screws. It only takes about an hour.
nassau66427 is offline
Old 09-27-2010, 08:56 AM
66jack
66jack's Avatar
That's what she said...
66jack is offline
Old 09-27-2010, 09:29 AM
67's
67's's Avatar
Try Dick at Virginia Vette
67's is offline
Old 09-27-2010, 10:21 AM
jprop
jprop's Avatar
If you have a little bit technical ability and a Dremel type tool this is definitely a do-it-yourself project. In a nutshell, you slide your new insert in from the front between the frame and the old insert. You don't tamper with the back of the door at all. For about about $25 and an afternoon of work your door will look new and completely original.
Search "glovebox insert" for detailed instruction.
jprop is offline
Old 09-27-2010, 10:39 AM
Vogie
Vogie's Avatar
Corvette Instument Service. www.corvetteinstruments.com
Vogie is offline
Old 09-27-2010, 10:51 AM
Corbrastang
Thanks! I found this article with google. Interesting technique to preserve the rivets. I was not aware that they were like the gas lid and were initially studs.
Thanks for the tips! I am going to do my best to try to make the door look better with some steel wool before hacking it up, but there is one scratch that is pretty bad.
http://www.lbfun.com/warehouse/tech_...R%20REPAIR.pdf
Old 09-27-2010, 11:10 AM
0Virginia Vettes
Former Vendor
Virginia Vettes's Avatar
Thanks Tom we do them
Dick
Virginia Vettes is offline
Old 09-27-2010, 01:03 PM
65 vette dude
65 vette dude's Avatar
I did mine myself a few years ago....pretty easy job. The only thing I didn't like was the repro aluminum insert. The finish on it was nothing like the original. The horizontal brush marks were way too heavy, and very obvious. I went ahead and used it, but every time I look at my door, it bothers me. Anybody know if better looking repro inserts are available now, and who sells them?
65 vette dude is offline
Old 09-27-2010, 03:29 PM
Bluestripe67
Support Corvetteforum!
Bluestripe67's Avatar
Received 2,125 Likes on 1,464 Posts
I tried the "slip it in" method,and followed the directions to the letter but could not keep it from scratching the new one. Bought a second one and did it from the back. In order to keep the tinny sound to a minimum, I put dense foam inside. It's very satisfactory for a driver. Dennis
Bluestripe67 is offline
Old 09-27-2010, 04:08 PM
Olustee bus
Olustee bus's Avatar
Chris
If you don't want to do this yourself, I have a friend in Trussville who is an excellent restorer. He has helped me on several things. He rebuilt my headlight motors which were it terrible shape and they looked brand new. PM me if you would like to contact him.
Olustee bus is offline
Old 09-27-2010, 05:44 PM
Lou64
Lou64's Avatar
Don't really see how "sliding it in" was an option, my 64 had zero room in there. Me and my dad did this the old fashioned way, although I wouldn't recommend without a drill press, as you can go too far through the old rivets and then your in trouble. I didn't do the hex heads with the drill at the end, but that's what the directions recommended. I am just thinking of RINT (Replacing It Next Time), not NCRS. Good luck.
Lou64 is offline
Old 09-28-2010, 01:49 AM
4440stevesvette
4440stevesvette's Avatar
Corvette Specialties did a excellent job on my glove box door. If your not in a big hurry, why not just wait until they are set up and running in Palm Desert,CA. and give the C2 forum sponser the business???
4440stevesvette is offline
Old 11-10-2011, 11:45 PM
Hitch
Hitch's Avatar
Originally Posted by vettesportdotcom
get out your bridgeport. drill center of rivets #29 .218dp. drill heads off w 5/16 drill. Using a bottoming tap CAREFULLY tap 8-32. file tops of post square. drill out emblem rivets attached to insert using super glue sparingly! assemble using button head screws. drill out center of screw. better yet sell your old one on ebay and buy a repro!
HOLY OLD THREAD.... I'm always interested in why some threads get bumped like this...
Hitch is offline
Old 11-12-2011, 02:26 AM
kskid
kskid's Avatar
The thread is a year old so its probably fixed by now.
kskid is offline
To Where to send Glovebox Door for Restoration?
Quick Reply: Where to send Glovebox Door for Restoration?
