Do these look like Flint Heads or Tonawanda?
Old 10-26-2010, 07:46 AM
btharbold
btharbold's Avatar
Default Do these look like Flint Heads or Tonawanda?
Hi,
I have been looking for a set of Flint heads in the right date range for my car, May of 65. I found a set but thought the humps might be a little too clean. Figured I would ask some of the experts here what they think. Are these Flint heads guys?
http://cgi.ebay.com/ebaymotors/ws/eB...m=330471050520
Brad
Old 10-26-2010, 08:35 AM
LSUvetteguy
LSUvetteguy's Avatar
St. Jude Donor '10
I didn't know there were F and T heads. Those look about like my 65 heads dated E55. M2C
Old 10-26-2010, 08:39 AM
btharbold
btharbold's Avatar
I had read that the Flint heads (which would be correct for vettes) had the double hump castings with a machined surface. The Tonawanda heads were left "as cast" but I have never really compared so I wanted to ask the experts.
Old 10-26-2010, 09:11 AM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
They're flint heads.
Old 10-26-2010, 09:19 AM
ktchir
ktchir's Avatar
Mike what tells you that they are Flint heads? (I am not doubting you I would just like to know for future reference)
Old 10-26-2010, 09:26 AM
Donald #31176
Donald #31176's Avatar
The cast date for the year on Flint heads are single digit.
Old 10-26-2010, 11:31 AM
MikeM
MikeM's Avatar
See Donald 31176 post.
Old 10-26-2010, 11:35 AM
chet b
chet b's Avatar
I have seen the T-heads with a T below the 461. The T is not raised but the T is a depression. Maybe an owner with T heads will chime in. The heads on E-Bay appear to be Flint.
Old 10-26-2010, 11:45 AM
ktchir
ktchir's Avatar
Thanks guys...missed that one completely
Old 10-26-2010, 04:21 PM
oldskydog
oldskydog's Avatar
Not all Tonawanda castings used double digits, I have a pair of 462 heads with single digit casting year and unmachined ends. I originally thought they were Flint untill I looked again and found a T cast between the spring seats and A "T" faintly stamped below the casting date as seen in the center pic.. One is dated H-13-6 and the other is K-14-6 and no evidence of grinding...not enough space to allow a second year character. One also has a Z (or N for Nodular?on it's side) cast near the spring seat on one end. One has a 25 cast below the first spark plug hole and the other has a 16 cast there. I also have a 68 327 engine Tonawanda casting with a single digit year.
The dead giveaway for the later Tonawanda head besides the unmachined ends, is the presence of the 2 digit number just below the spark plug hole. Not sure when this started, but the single digit casting year must have started around 65-67.
Old 10-26-2010, 04:39 PM
65tripleblack
65tripleblack's Avatar
Also.................
Tonowawanwndana heads don't have the double humps machined like the Flint heads.
Tonowawanwndana heads have the double humps rough cast.
Old 10-26-2010, 04:46 PM
MikeM
MikeM's Avatar
Yer a little late to the party Joe. That's already been mentioned 3-4 times.
Old 10-26-2010, 04:59 PM
MikeM
MikeM's Avatar
Originally Posted by oldskydog
Not all Tonawanda castings used double digits, I have a pair of 462 heads with single digit casting year and unmachined ends. One is dated H-13-6 and the other is K-14-6 and no evidence of grinding...not enough space to allow a second year character. Not sure when this started, but the single digit casting year must have started around 65-67.
It might be a little tough to find 461 heads with those Tonawanda casting features.
Old 10-26-2010, 05:00 PM
65tripleblack
Ah, yes! I hate it when that happens.
Some people need repetition for it to sink in. Three times ought to do it.
Question: do Tonowawanwndana heads have the humps machined?
Old 10-26-2010, 06:02 PM
oldskydog
oldskydog's Avatar
You may be right as the earliest T castings I have with single digit year are the ones pictured above, but I have some 64 Tonwanda heads with double digit year that also have the 2 digit number below the spark plug hole. I've never seen a Flint (Saginaw) head with those digits.
I also have a pair of 68 291 T castings with single digit year and 2 digit numbers by the plug holes and another set of 68 T castings the same way. It is beginning to look like the change to single digit year on T castings started near the end of 66 for the 67 model year.
My only point is that single digit year casting by itself is not a definitive indicator of a Flint (Saginaw) casting.
Old 10-28-2010, 07:59 PM
oldskydog
oldskydog's Avatar
Strangely enouugh, here are some 461 single digit year tonawanda heads.
http://cgi.ebay.com/ebaymotors/66-Corvette-Nova-Chevelle-Chevy-327-Heads-461-H-date-/390018263431?pt=Vintage_Car_Truck_Parts_ Accessories&hash=item5acee66987
Old 10-29-2010, 03:27 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
Those are the small-valve (1.94/1.5) heads, which are the only ones you'll see from Tonawanda; they didn't make the 2.02/1.6 versions. The Tonawanda head line didn't have the station in the transfer line that performed the intake valve unshrouding cut in the chamber wall on big-valve heads - that station only existed at Flint V-8.
To Do these look like Flint Heads or Tonawanda?
Old 10-29-2010, 04:59 PM
65tripleblack
That is a photo of a 462 chamber. Note the relief above the spark plug.
461 chambers don't have that relief. They have a flat (quench) area above the spark plug, and, consequently, a smaller chamber volume. The redeeming factor for the 462 is that it has better spark plug location; the spark plug on the 461 head is closer to the deck than on the 462.
Old 10-29-2010, 06:47 PM
MikeM
MikeM's Avatar
AWWWWWWWWWWW, why did you have to ruin it?
Old 10-29-2010, 06:55 PM
4440stevesvette
4440stevesvette's Avatar
Originally Posted by btharbold
Hi,
Brad
OUCH!!! - they seem pretty spendy to me at $400 and need a though going thru.
Quick Reply: Do these look like Flint Heads or Tonawanda?
