58 - Fouled spark plugs - running rough - see pics
#41
JT..thanks for the tip...I'll see if I can look inside.
As far as the Protronix...I don't think that is the problem. I have a timing light and its solid 4 degrees on the timing tab...it doesn't bounce around. I also have an oscilloscope (not engine scope, but actual oscilloscope) and the timing marks look all the same height. Lastly...it ran great with the pertronix and it rev's right up when it starts to clear up.
No video please as I'm very cheap and the $14.95 dial up system is very slooooooooow.
Thanks,
Jerry
#42
Mike...I rebuilt the carb. Its working great. I made sure all the orfices were clean. I blew carb cleaner in all the holes and made sure they were cleaned out.
The main problem is the car runs like crap when I first turn it on...doesn't idle....and makes this sound like something is ratteling inside the engine. It also smokes and misses like crazy.
However, when its all warmed up and has been running...it sounds fantastic.
Here is a video I just took of the engine warm. As you can see the engine runs great! Rev's up...and no noise! Sounds like a completely different motor.
View My Video
View My Video
