soft top installation cost??
Have you looked into installing the top yourself? Al Knoch sells a dvd on how to do it, and it doesn't look like it's too hard. I'll be trying it myself here in the next week or two.
Gerry
Gerry
I watched the Al Knock DVD - twice...and then I couldn't get my car to a professional fast enough. There are some tricks and tips to get to a really nice fit that aren't in that video. If you are just doing a cheapee vinyl rag top and screw up its not the end of the world....if you are doing a high-end, expensive Stayfast Haartz top then you do NOT want to learn-on-the-job with that material. One bad cut and you get to buy another one.
My '65 canvas top was installed 01/04/10. Bought from these guys; I don't think you'll be disappointed:
http://www.convertibletopguys.com/co...rolet-Corvette
Haartz Black Stayfast Canvas Top w/Plastic Window & Supplies @ $349 + $20 S&H.
Local Professional Installation W/New Pads @ $450.
Total: $819.00
Total: $819.00
Total: $819.00
Total: $819.00
Total: $819.00
Total: $819.00
I don't think this is a job most guys really want to tackle, no matter how "mechanical" they are.
(Like you said earlier, "one bad cut and you get to buy another one"). IMHO, I would never have considered doing this job really no matter what the labor cost was, because it would still be cheaper than my time screwing indefinitely with it and probable multiple top purchases. Plus, I figured if the shop that specializes in this type of thing screwed it up, then they can replace it.
The more he talked the happier I was to write him a check.
Tom E,
That is something I hadn't really considered...point is let the pro's do there thing ...and if they botch it it's on them...there can be wrinkles and miss alingment possibilities also...
Tx for the in put....
Bluzrocker
Bluzrocker
However, I found my installation guy(s) by talking to a bunch of other guys that drove great looking Hot Rods that all had custom made canvas tops and interiors at a car show. They said most of the really good installers are sometimes kind of hard to find because they don't advertise - most of their business is by referral word of mouth and their shops are not always easy to find.
In many areas of the country finding people that know how to install a convert top is becoming more and more difficult. It is far from being a routine job. For some newer convert's even dealers don't know who to turn too to replace a damaged top
I have done about 300 Corvette tops. Mostly C-1, C-2 and C-3's. I only do Corvette tops. I can tell you that there is a different challenge with each car. Especially projects that may have been hit or have a top frame from another car. Then there is the rust factor. C-1's are the hardest. The frame itself is very flimsy and is made ridged when the canvas is installed. I started doing the tops when a local shop botched my first Corvette top. I ruined the first top I tried to install. Poked a hole right thru the canvas. One thing I have told anyone who is trying to do this themselves is that if you try to go by the directions given in the shop manual you are asking for trouble. A good start is the Al Knox video.
#33
What about the total cost to install on a car that is "soft top delete"?
I am looking at getting a car that has been described as such, so I am assuming this means there is no hardware at all currently installed on the car to accept a soft top.
#34
Al Knoch buys frames, therefore he would carry frames sutable to recover wherever you purchase the materials....a phone call to them could satisfy the frame issue and hardware
#35
convertable top installation
It cost me 400.00 for the install, top looks perfect. The down side ,I didn't assemble the top with all the new weather stripping after i took the frame all apart and refinished same. I should have fit the frame to the car after I was done wit the rehab. Result, a beautiful top that doesn't fit the way it should, my fault . What I learned was make sure the frame fits the car before anyone puts a canvas over it or you may be very dissapointed in the result . I hope the helps. Jeff
#36
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The tops themselves are not all that hard to install but you should have the correct equipment and patience.
I've put the last two tops we installed on our Facebook page in hopes that it will help someone do their own installation.
1) The frame needs to be refurbished... All worn bushings, rust and other issues should be repaired. The top should be smooth and non-binding.
2) Always fit the frame to the doors with the new weatherstrips prior to a top installation.
3) If you have a hardtop always adjust the door glass to fit the hardtop first, then adjust the softtop frame to match the door glass.
There are a bunch of other tips that might make your job easier. I think anyone can do the installation. Plus there are plenty of people here to help you if needed.
Expect the un-expected.
All new top kits come with pads, straps and hold-in cord.
60 top installation https://www.facebook.com/media/set/?...6912924&type=3
65 blue top installation. https://www.facebook.com/media/set/?...6912924&type=3
Willcox
#37
I have been looking for someone to install tops on my C1s for the past four years. every installer I contacted in the northwest Indiana area say they have no one experienced in installing a top on any C1. I would at least like to have a top installed on my 59. the last installer left me topless when he discovered it was a bigger job than he expected. he couldn't get the new top to fit and after reordering a new top he just put kept putting me off. if anyone knows of a installer in my area let me know.
#38
Former Vendor
About an hour and a half from you is Steve Mann.. I'm not sure if he is still doing the work or if he does soft tops... but you might give them a call. Mann's Corvette Shop Inc 13644 McKinley Highway,, Mishawaka, Indiana 46545
(574) 256-1981
(574) 256-1981
#39
Takes me about 4-5 hours to do a top, from start to finish, assuming the frame is clean to start with. I think that anything over $500-$600 would be too expensive. Obviously, blasting and painting the frame would not be included in this.
Regards, John McGraw
#40
Al Knoch gets $525.00 to install 'his' tops....there isn`t any one in the country that can do a better job..and in the mood does several a day....I mention this because others have attempted to install the tops and will compare or use Al`s prices...and it could be a idiot installing the tops... A trick 'PRO' installer that had never done a Vette and shall remain nameless, recently took 3 days fuking the top up in the process did a lousy job and then charged Al`s prices .Many here on the forum have installed tops and did a great job,..{no wrinkles or too tight} and they look as good as Al`s
