Greenwood Suspension resurrected
Our rendition of Greenwood's 5 bar suspension
Well after a year or so ...... We have completed the welding & assembly of the bearing housing bracket (No longer a trailing arm).They turned out better than expected. Now maybe I can get moving on this SWC project. My Welder called them " Suspension Jewelry" ! Yes...... that is 304 -L Stainless steel.... Assembly should start shortly .....as it is My day off and its raining
Yes yes yes! Are you planning on mass producing these? I'd sure like to get a set!
Groovy jay: I couldn't mass produce this set up..... would certinly be bankrupt after 10 sets. Cost of Stainless Steel , Splined -Telascoping half shafts, water Jet or lazer cut patterns, then tig welded up. I have just enough pattern's cut for 2 sets......
If you need to get rid off the second set I'd be more than willing to buy it from you!
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
It is, essentially, the same architecture as the C4 rear suspension.
Very nice fabrication!
Jim
This design goes a step further and eliminates the Half-shaft's as a active suspension member. Hence the need for telescoping splined shafts. The C clips no longer anchor the wheel's camber angle . It has unlimited adjustablity. Better than the C-4 ...........IMO
[IMG][/IMG]
You "can" have it all........
Photo during development stages. Note that this design can be used with the Mono leaf spring or Coil overs If desired
Mr. Guldstrand's
Harry: I considered the Guldstrand System....... Even talked to Mr. Corvette," Dick Guldstrand himself ....He answers the phone at the shop when he's around. Great Man! ( I digress ............his set up requires considerable modification to the frame for the links to clear. So it's $2700 + labor
I might add that your design is much superior to the guldstrand kit.
I don`t know what you consider "considerable" but butchering the frame in those pics above wasn`t necessary. I had an old SCCA GT-1 race car here with an original RPF 5-link ("RPF as in Bob Riley, Protofab and George Foltz the original designers and builders of what is now known as the Guldstrand 5-link) and it required no where near that amount of "butchery"...I sold the RPF 5-link and then sold the car to a guy who vintage races it with trailing arms...
It's All Good
Thanks for the Comp GroovyJay. I borrowed your photos from another forum to illustrate. The credit for my design should go to a fellow Italian brother, who did the CAD and development.
Redvetracr:
It's really an 8 link ................ 6 link is a name someone came up with as a stock system (Dragvette) w/ 2 additional links ad 2 trailing arms. 5 bar is a name for a Guldstrand/Riley and also a little the Greenwood & C4 suspension corner, 2 trailing links, a camber link a halfshaft and a toe link. The C4 & Greenwood ones use a rear toe link, the Riley/Guldstrand one uses 2 lower camber rods where the relative adjustment of these 2 set the toe.
Redvetracr:
Redvetracr:
Dick is a gem for the hobby. When I was actively autocrossing (70s and 80s), I used to trade notes with him. He answered every letter personally. Mostly just short notes, but every one was answered. I wound up buying a lot of chassis parts from him for 4 different cars.
Harry
Received 1,857 Likes
[IMG][/IMG]
[IMG][/IMG]
Yep Johnny......your Viper and the C5 , C6 went to the double A arm rear's now. SRIII is offering that setup on the C2 & C3 frames too. But I'm going to keep the SWC stock frame. Fortunately the only Mod is welding 4 mount Tabs on the frame below the trailing arm pocket. It's been allot of work and finally seeing the light at the end of the tunnel.
