340hp set-up and 461x heads
Old 02-25-2011, 11:52 PM
Glasshole
Glasshole's Avatar
Default 340hp set-up and 461x heads
Now that I have put the Arizona Speed FI unit and vortec heads on my
'63 I am thinking of selling the complete 340hp set-up (manifold, carb, air cleaner, dist, linkage, fuel lines etc.) and the 461x heads to re-coup some of my costs. The 340hp set-up isn't original as I have an FI car that had the FI unit replaced with this. The 461x heads are the original ones. Will these things add any value to my car at re-sale time or should I sell to someone who could use them now?
Thoughts?
Old 02-26-2011, 02:07 AM
MiguelsC2
Support Corvetteforum!
MiguelsC2's Avatar
St. Jude Donor '10-'12-'13
If they aren't in the proper date range for your car? I don't see any value in retaining them.
Keep the heads!
Old 02-26-2011, 02:45 AM
Westlotorn
Westlotorn's Avatar
Received 1,271 Likes on 812 Posts
I don't know the value of your used parts but I am very interested in how your new parts work. Are they on a 327 or 350 block? How do you like the changes?
Old 02-26-2011, 09:11 AM
Glasshole
Glasshole's Avatar
They are on the numbers matching 327. You can read all about it on this thread I started last summer:
http://forums.corvetteforum.com/c1-a...has-begun.html
Old 02-26-2011, 09:12 AM
Glasshole
Glasshole's Avatar
Keep the heads!
They are in the proper date range. Just not original to this car.
Old 02-26-2011, 10:02 AM
65tripleblack
65tripleblack's Avatar
I'll give you $100.00 for the pair.
I would save them if I were you. Unless you are dirt poor and/or need the money to buy methamphetamine.
Do you live in a double-wide?
Old 02-26-2011, 11:01 AM
EFI guy
8th Gear
EFI guy's Avatar
Definitely hang onto the heads, somebody will love 'em later since they are THE original heads and good ones at that. The rest can be sold when you are convinced (like a year from now) that the FI worked out as expected. JMHO
Old 02-26-2011, 02:41 PM
Glasshole
Glasshole's Avatar
Hey where can I buy that good meth for $100.00?
And it's a triple wide cause I park the car in there with us.....geeeesh
Old 02-26-2011, 02:43 PM
Glasshole
Glasshole's Avatar
Yeah that's kinda what I was thinking too......
Thanks for the advice fellas.......
Old 02-26-2011, 04:27 PM
MiguelsC2
MiguelsC2's Avatar
Since none of those parts are serialed. The date is the big matching issue. Keep EVERYTHING!
To 340hp set-up and 461x heads
Quick Reply: 340hp set-up and 461x heads
