Tach drive distributor - 65 L79
Can you recommend a good, over-the-counter tach drive, vacuum advance distributor (w/points is okay) that can be installed right out the box and the car will perform as it's suppose to? Or do all need to be bench checked on a sun machine? I don't have the shielding yet but it'll come in time so the distributor needs to be compatible.
Anyone have experience with the reproduction distributors offered by Volunteer Vette, Corvette Central or Mid America? I know they're pricey.
If I choose to go the rebuild route, can a 1111490 be converted to a 1111087?
Thanks,
Thanks,
If the core you re using does not need major work (housing bushings, main shaft replacement) then rebuilding it to 1087 specs is an excellent option. If you need a source to do this work I will be happy to give you a contact.
I'm in the same boat too. I'm looking for a replacement stock/ over the counter distributor that is a tach drive. One that I could drop in, connect to the tach on my '62 and cover with my ignition shielding. Wouldn't this be the same Tach drive distributor - as a 65 L79 has? And what distributor is part # 1111087?
I'm in the same boat too. I'm looking for a replacement stock/ over the counter distributor that is a tach drive. One that I could drop in, connect to the tach on my '62 and cover with my ignition shielding. Wouldn't this be the same Tach drive distributor - as a 65 L79 has? ...
Thanks,
Thanks,
If you know how? You can do it with your distributor in the car, It takes quite a few R&Rs to get it right.
1111490, 65, 74, 79, connecting, corvette, delco, distributor, ditributer, drive, hei, mainshaft, points, remy, reproduction, tach
