headlights flicker - turn lamps flicker in response??
headlights flicker OFF / turn lamps flicker ON ???
ok, odd electrical issue here.. '64 vette, but I made my own forward lamp harness because of a custom headlight setup. low beams only, no high beams. original turn signals.
over bumps, i would assume due to a loose connection somewhere, my headlights flicker off and simultaneously the dash indicators for BOTH turn signals flicker on. this strikes me as quite odd since left and right turn signals are fed by two different wires and the headlamps are powered by their own wire.
also, without the headlamps on, only the running lights, over bumps both dash indicators for turn signals blip ON.
the condition occurs when the front wheels strike the bump and it is very brief blip.
i had a friend stand outside the car and verify outside light action with the running/turn lights. it seems that when the dash indicators flash, only the front turn signals flash also, but not the rears. so all together, two front amber bright side of bulb flashes on as does the dash indicators for these bulbs. the rears do not flash. if the headlights are on, they flicker off at the same moment.
i am suspect of wiring behind the cluster at this point and guess i will pull it out (again) to re-check connections. the dash harness is new.
other than chasing all the connections looking aimlessly for a problem that i can't duplicate in my garage, anyone have an electrical explanation for what's happening?
i could understand a loose ground causing a flicker OFF for the headlights, but how are the front and dash turn signals flickering ON?
1 Post
i cannot verify that the lamps actually turned on the bright filaments when the dash indicators came on, but i assume they did.
my only guess at this point was maybe there is something built into the headlamp switch that will turn on both turn signals if the healights lose circuit while in headlight mode? i don't know.. there is no way both turn signals should otherwise come on together..
one final alibi, i do have the purple wire for the front running lights moved to the #3 slot on the switch socket so they stay on with headlights. i do not suspect this to be my issue with the flicker though.
well i'm still stuck on this one.. bulkhead connector is in great shape, i bought a new LL under dash harness with fuse block and a kind forum member gave me the bulkhead connectors for my custom engine bay harnesses which were in near new condition..
i'll re-check grounds, but i don't understand what a loose ground has to do with the turn signal indicators coming on.
the turn signal indicator blips i confirmed occurs in either running lamps or headlights modes, but not in lights off mode.
i could understand a loose ground causing headlights to flicker, but this situation with the turn signal indicators both flashing at the same time confuses me..
i played with the headlight/dimmer switch connection as well in the garage and couldn't duplicate the problem.
1 Unplug the rear harness connection to the main dash harness and test (lights on) to see if the problem goes away.
2 If not, reconnect the rear harness, unplug the LH bulkhead harness, and test (lights on) to see if the problem goes away.
3 If not, the problem is in the cabin.
thanks magic. that diagnostics method makes sense.. i will give it a try this weekend to hopefully isolate which section of the harness has the issue. more to follow!
well just a courtesy update, cuz yeah, sometimes it takes me a month to get back out to the garage and fix things..
after a couple hundred more miles, the symptoms got weirder.. the right front amber would blink the dim filament with the turn signal and the bright filament never lit. neither filament came on with running or headlamps, but the dash indicator stayed on solid.
i finally found a loose ground connection, i apparently crimped the ground wire wrong in the ring terminal for the front right amber light.
ground wire fixed, all lights appear to be functioning normally again, at least stationary.. i still have to drive and hit some bumps to make sure the flashing symptom is gone.
chrislyn called it on the first reply to this thread! feedback is the only thing that explains the weird lighting.. current was looking for another way to ground when the primary ground was lost i guess..
cheers!
cheers!
