Anyone ever see factory AC on a fuelie?
Received 1,843 Likes
When I mentioned this alternator location in post #4, I excluded the possibility of PS.
This alternator location will not interfere with the air cleaner or the S tube.
I'll look at my car in a few and see if anything else might be in the way but I don't think so.
Back in 1976 I think, a guy named Bob Patterson in East Alton, IL had factory air in a '63 coupe with the factory FI setup. I don't know which was original to the car, or if either were original to it, but he had them both in there.
I can't remember how the alternator and air cleaner was handled. I thought I had some old pictures around but I haven't found them.
St. Jude Donor '07
here's an option from alan grove. my Vega's a/c compressor was mopunted stock down low like this; downside is that it is more subject to getting wet or road debris.
Bill
Small Alternator
After looking at this thread I Googled “driveshaft mounted alternator” and was lead into discussion on one of the Mopar sites. One of the guys there was looking into using a “small” alternator from a Toyota or Nissan. I’m not sure how must clearness you have on the driver’s side but maybe you get a bracket made to fit one of the rice burner units.
You could try finding an electric AC compressor. Could be mounted everywhere you find a room for it.
http://www.alibaba.com/showroom/elec...ompressor.html
This is what I was talking about. Why won't it work?
http://www.nostalgicairparts.com/pop...ge.php?pid=239
Only problem with FI car is the big oil pan, can't have PS even you are old and decrepit, which is how I feel every time I crawl out from under the thing.
Thanks!
I added power steering and Old Air Products AC to my '63 FI coupe several years ago but I ran a cone air filter instead of the original FI air cleaner. That setup worked well and, since the car lost its originality with the addition of AC and PS, I didn't worry too much about the lack of an original air cleaner.
I think what I'll do is put the car back together without AC compressor for now, and once everything is all back in place then explore where space actually exists to add the AC compressor or move the Alternator to make room. Not ready to start buying brackets and experimenting right now, lots of other stuff to finish first. Once car is up and running I'll take it over to the CnC place I found as they are fabricators and have them figure the best way to mount the AC unit. Doesn't look like it will be an easy task to accomplish given the limited space to work with.
#36
Roger that - no need to sweat it... until it hits 105 outside... maybe I really don't need AC, which would cause the wife to stay home when I take the 65 out... hmmmmm
#37
Looks doable to me but I can't say for sure.
#38
Received 1,856 Likes
If you use the side-mount '57 F.I.- type air cleaner, you can use all factory brackets to add the A/C, and P/S too (if you change the oil pan or use the Borgeson gear instead of the factory system). If you use a Sanden compressor instead of the factory A-6, Alan Grove (and others) have that bracket set.
#39
St. Jude Donor '07
http://cgi.ebay.com/ebaymotors/1957-...Q5fAccessories
Bill
ps: shipping is only $15
#40
here's one for only $1850.00...
Bill
Bill
