T10 gear oil
Old 06-15-2011, 09:12 PM
thoyer
Support Corvetteforum!
thoyer's Avatar
Default T10 gear oil
Recommendations for gear oil top put into my 1960 T10?
The car has sat idle since 1985. I drained the old oil last weekend and inspected the gears. All looks real good gear wise, but the oil I drained did not smell like 90wt like I'm used to using in manuals. It was lighter in color and thinner in viscosity.
Thanks,
Tom
Old 06-15-2011, 09:28 PM
midyearvette
midyearvette's Avatar
Thanks,
Tom
i would stick with the original 80-90 weight....the tolerances are looser on older transmissions and that is what it is designed for
no need for a fancy synthetic.....jmo.....good luck.....
Old 06-15-2011, 10:11 PM
62Jeff
62Jeff's Avatar
Is there a real issue with modern 80-90w gear lubes, and the soft metal components?
I hear that certain additives in the newer lubes are hard on the softer components, but not sure what is real and what is myth.
Old 06-15-2011, 10:19 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
we did a poll of major lubricant suppliers back when we changed transmissions, and it is true, by their own admissions, that there is a problem with some formulations attacking brass synchro parts; unfortunately i don't remember the results of who is good or bad except that we ended up using valvoline.
subsequently i ended up changing to ATF for my MY6 because the thicker oil didn't shift as smoothly.
Bill
Old 06-15-2011, 10:23 PM
62Jeff
62Jeff's Avatar
Originally Posted by wmf62
...unfortunately i don't remember the results of who is good or bad except that we ended up using valvoline.
Thanks Bill, that's the brand I use anyway, so I'll just watch for damage when I pull the tranny out of the 62 later this year, but otherwise will assume my Valvoline did no harm.
Old 06-16-2011, 12:03 AM
Pilot Dan
Pilot Dan's Avatar
I've spoken with a few guys who are experienced rebuilders and they unanimously vote for 80-90 weight original type gear oil and NOT synthetics in these older boxes. Pilot Dan
Old 06-16-2011, 12:22 AM
jimgessner
jimgessner's Avatar
Default CHEVRON DELO GEAR LUBRICANTS are my choice
Chevron Delo Gear Lubricants ESI (formerly Chevron Delo Gear Lubricants) are premium grade, multipurpose gear lubricants. Approvals include MIL-PRF-2105E, API Service Classifications GL-4, GL-5 and MT-1, Mack GO-G, GO-H and GO-J (80W-90). These lubricants are the only non-synthetic gear oils approved by Eaton and Meritor (formerly Rockwell) for 750,000-mile extended warranty service in axles. Delo Gear Lubricants ESI rival the performance levels of synthetic gear lubricants and are a cost-effective alternative to synthetic fluids.
Many years at the race track have backed up these products.
Old 06-16-2011, 12:54 PM
thoyer
thoyer's Avatar
Thanks guys. You all validated my 80-90wt thoughts.
I hope to be driving this beast in a few weeks............
Tom
To T10 gear oil
Quick Reply: T10 gear oil
