Tubbing a C2 Rear - Top Clearance Issue
My dad and I are about to begin a process to bring back a '63 C2 Roadster back from a 36-year retirement... with a resto-mod approach.
We're looking to have go the custom frame... C4 suspension... approach and would like to "tub" the back end and have the rails narrowed to allow for C5/C6 size rubber to be run in the rear...
After taking a look at the convertible top frame it looks like we'll have some serious clearance issues with the collapsed top vs. the deck cover vs. tubs... I know it probably won't be simple, but I'm interested to see if/how anyone has overcome this (without widening the fenders!)
Thanks - Ben
Thanks - Ben
Ha - we've considered that approach (and do have a HT) and the idea of just taking the soft top out... but it kinda defeats the idea of having a real "Driver" of a C2.
Especially with PA's constant summer weather forcast of "...30% chance of showers..."
This is yet to be decided. (and I know it must be decided prior to exact mods)
I'd like to have the capability of running stock, or stock compatable wheels from a C5/C6... I want to avoid the need for any custom offset rims.
At the very least we'd like to run what's on the '93 donor car which are... 275/xx/17's rear and 245/xx/17's front... I'd love to run staggared 18's/17's but I'm open to suggestions/warnings...
Now, on a C2, you'll need a 65" outer bulge width at the tires (assuming it's not stupid low). Factor in the size the 295's and a minimum of 1" of clearance to the frame, you'll end up with a 39" outer frame width (stock is roughly 45"). So, you'll have to narrow the frame 3" per side to get the clearance you need for *just* a 295mm rear tire. If it were me, I'd make the car a true roadster and forget about the convertable top.
Before I say anything else... YOU GUYS ROCK!
It's very reassuring to have immediate responses and input from you guys... I just wanted to say that before I get any further along on this thread... I'm a newbie - so THANK YOU in advance for the help...
Also - I tried to post a photo of our starting point under my profile if you're interested... please take a look...
Tubs for tops
Take a look at my website. Step by step photos. A very tight fit, but will work. Not for faint of heart!
Jim
http://www.64corvetteroadster.com/
Jim
Jim
Jim
Also John McGraw.
This car has 325R19's, is stupid low, and "appears" to have a working top.
http://web.mac.com/hedgesspeedshop/H..._Corvette.html
if it is just about rubber on the back, i have 295/50/15 on the rear of mine with a stock frame. double offset trailing arms and 1" wider gtscustoms rear fenders were used, plus custom wheels (15x10 w/5" b.s.)
but i think you asked about using late model vette wheels, which have a lot more backspacing.
It can be done, but it's a tight fit. MAKE SURE YOU HAVE THE PADS AND TOP MATERIAL ON THE FRAME WHEN YOU FIT IT FOR CLEARANCE. We almost didn't get the top lid to close on Jim Toma's car after the top canvas/stayfast was installed. You will add almost 2" to the collapsed bare frame with the material installed.
Mike Coletta
Mike Coletta
Jim
Jim
We don't want to do any external mods... although I have to say... the 1" wider fenders do look NASTY!
Mike Coletta
Mike Coletta
I figure a tight fit = less rattles so this is probably a good thing right?!
Kudos on one beautiful ride Jim... What fun would there be if this were easy right?! I see that you notched out just a bit for the top bow to set into the wheel wells... nice touch. Any issues with full compression of the tires hitting this notch?
Jim
This may be the route we take to keep things a bit more simple and make sure we have use of the top without the addition of a project on a project... as most of you understand, I'm sure, is once I get an idea in my head it's hard to shake... and a challenge is hard to walk away from...
If you don't mind... What for wheels/offsets are you running Poorhouse? ...and what is the distance from wheel mounting surfaces side-side?
So I was asked yesterday... do we really "need" to tub and run bigger tires... and of course the honest answer is "no" and 245/45/17's will give a MUCH improved look and feel from the original pizza cutters.
