12-bolt Tom's Differential Conversion
I recently got my 12-bolt differential conversion back from Mike Dyer(tracdogg2). This will be going in my red '67 convertible that I am putting a big block in. I was concerned about the strength of the factory diff so a Tom's was in order. I decided on the 1350 kit because I didn't want to have to cut the fiberglass on this car as you have to do with the 1480 kit that I currently have in my '67 632 car.
Tom recommended the HY-TUFF inner axles and Mike recommended the Billet Flanges.
I went with the following Tom's Differential components:
12V-KIT (12-bolt Corvette Conversion Parts Kit with 4.11 gears)
1350-VAK (1350 Vette Axle Kit with upgrade to HY-TUFF inner axles and Billet Flanges)
C10V-HDRC (H.D. Rear Cover)
Mike supplied his own custom left-side cap. At this point all of the work that Mike has performed is first class. Of course, the real test will be when I take it out to the drag strip.
I have included some pics:
Once I get the motor completed, my plan is to make a few DynoJet runs with the factory 3.70 rearend and then switch to this new 4.11 rearend and make a few more runs to see what the differences are.
Steve
Steve
I, for one, will be very interested in the dyno results. Do you think the 12 bolt will eat more horsepower? I have the 10 bolt upgrade with the 1480 series stuff in my 69, and have always been curious of the power penalty I am paying. Good stuff Steve.
Bill
Bill
How close are you getting on your new manifold deal? As I have said before, I am anxious to see how that all works out.
Steve
Thanks, Bill.
Steve
It will eat up a little hp due to the higher polar moment of interia. Also from the change in hypoid angle on the gear teeth going from a 3.70 to 4.11. But nothing compared to Ford 9 in which has a very high angle.
Mike
Mike
I've heard this is the way to go so congratulations and as already mentioned, that is one serious looking set-up.
Originally Posted by vetrod62
It may eat up a few HP, but that is better and cheaper than leaving parts all over the ground.
Steve
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Strong is good!
You ought to see the size of my Dana 60 inside sometime with a 9.75" ring gear! AND 3.5"x.134 wall halfshafts and 1480's! Heavy stuff..but I haven't touched it since I put it in many years ago!
Steve
632C2:
I felt the same way ...I didnt want to chance failure's on the SWC 's Six link Suspension . Tom 12 bolt conversion should do the trick for this application also. I decided to go back to 3:73 from 4:11's for the overall drivability with TKO600. Not as beefy as 427's Dana 60..... but this sucker will handle like a rail . And yep ...that's 304 stainless components & Splined-Telascoping Half shafts.
Steve :
It's an old concept (1970's) Greenwood ... Just our Italian renditions of it. Been working on this............ off and on for a year and a half. I've fabbed two sets of these ....one for another project.
http://forums.corvetteforum.com/c1-a...surrected.html
Wow you dug this one up from the archives:
Not if you go to a larger driveshaft and 1350 joints. Here read this.http://forums.corvetteforum.com/c1-a...65-needed.html
looks good for sure,
Ive never had a problem with the actual rear end, or gear, its always the bolts or snubber? bushing that results in my broken parts.. How does this kit upgrade that?
