Ground Strap on Accelerator
On my 65, the ground strap on the accelerator has broken. Its mostly attached to the accelerator but I'm not seeing where the other end has broken from. Any one know where it supposed to be attached?
I'm nearly positive it goes to the rearmost intake manifold bolt. Mine had frayed off, and there was still a lug with a bit of copper groundstrap attached to it at that bolt.
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
So, what exactly are we grounding this for?? Is it another RF interference ground? Thanks
The long answer is almost impossible to explain without leaving people scratching their heads. It all started with me thinking my wiper motor was bad, but by adding a test/extra ground wire the wiper motor works fine. Knowing that ground strap was broken was a hopeful easy fix.
The crazy thing has turned out to be that if I connect my test light to a ground, and touch the wiper motor housing the wiper motor is hot. But not to get to far ahead of myself as I still need to do some investigating before I ask, but it appears that there is a single plug connector on the lower part of the wiper motor that I "think" (i'll be hoest i'm not 100% sure what it is for) is supposed to be a ground but the wire connected to it was a hot wire. I also need to determine what exactly the 2 prong/plug connect wire are hot and ground two hots, two ground etc.. (i'm not electronics expert)
While I'm typing all this I'll ask. The wiper switch in the dash as 3 prongs, but on mine, only two are connected by a double plug the 3rd single prong has nothing connected to it. Is that correct or is there supposed to be something connected to the single.
Hopefully, that didn't leave everyone scratching their heads.
It's all new to me and I'm just trying to take my time and figure out whats amiss. Any advice would be greatly appreciated.
Third Prong on Wiper Switch
Two prongs go to the wiper motor to control speed. Third prong is for the washer pump and I think it has a separate connector. Look for a single connector with a dark blue wire hanging around. That should be the pump wire.
To be honest I haven't played with my wiper motor (it's CA and I don't drive it in the rain). But looking at the schematic, the wiper motor gets power and then looks for a combination of grounds from the wiper switch to control the speed. No grounds - Off, both wires grounded - lo speed, the black/light blue wire grounded and the other open - hi speed.
Received 1,857 Likes
The main connection at the wiper motor has three wires - the center one is brown (12V to the motor), and the end ones (yellow, and black/light blue) are motor field grounds. The washer pump wires are brown (12V) and dark blue (ground from switch).
Great diagram below (from Buns) shows how the wiper and washer circuits work.
I'll take a guess, if nothing else it hopefully will elicite a correction.
I suspect that as the gas pedal moves on the throttle rod, it creates static electricity which is otherwise isolated from the chassis due to the nylon fittings on either end of the accelerator linkage.
The ground strap at the linkage would allow that static to discharge, preventing the AM radio from making static popping noises.
