1966 L79 Rear Axle Ratio confirmation
I pulled the numbers off my differential today, from what I can see, which was hard to get a clean read, it looks like my differential is marked " A O 10565 The last 5 is very difficult tor read but I think this is what is stamped on the rear Differential.
From what I have read I think this is a 3.70 Posi, 4 speed 327.
I will look again to make sure it is not an A Q 4.56 posi.
It is a L79 4 speed original car but I had never checked the differential.
I have not yet driven this car. It is a long project waiting for time and money. I have been aquiring parts and planning ( dreaming ).
Some of the rear diff ID numbers indicate Wide or close ratio on the 4 speed, any idea which this car should have, I suspect wide ratio M20would be the standard.
I think Your "AO" is probably right. The "AQ" would I think be a rare find and sure not something I would want to drive on the street for very long. My 66 L-79 has a "AN" (3.55) and a M-20. I think that is pretty common among L-79s and a good combination on the street.
My 66 L79 has the same AO (3.70) designation on the diff. I think I have a pic of it somewhere. The trans in my Mosport Coupe must have gotten destroyed long before we got the car in '89 so it now has a wide ratio Muncie in it but from what I've seen, most L79's with 3.70's came with close ratio boxes but didn't think the diff code would shed light on whether the car came with a close or wide ratio box.
Mike T.
Mike T.
The cheat sheet I have shows differential codes for small block and big block, some of the codes indicate which 4 speed and some do not. Some show the car could have had a powerglide. The AO code says Positraction 4spd 327. Thanks for your imput.
remember how old these vehicles are. some one could of changed the gear set over
the years and left the tag. chances are they would remove the tag. but ya never know.
jim
jim
Thanks guys, I will go through the differential once the frame is done and for sure I will know the ratio when I pull the cover but I was curious today and pulled the numbers just to check. I appreciate the help.
Received 1,856 Likes
The '66 L-79 could be ordered with either the M20 wide-ratio or M21 close-ratio box (first year that choice was available); 3.36 axle was standard with the M20 with the 3.55 optional, and with the M21, a 3.70 was standard, with a 4.11 optional. No other ratios were available with the L-79.
I guess that was changed for '67, then? My '67 L-79 was built (I have the window sticker and original bill of sale) with a 3:36 axle and a M-21 transmision (2:20 1st gear ratio). Not a good combination for making a clean smooth start! I've got a Tremec 5spd with a 3:27 !st gear in it now - a much better combination for all around driving, especially with the .67 OD 5th gear!
