1965 Clock Repair
1965 Clock Repair
My dash clock is in amazing shape and actually worked up until a year ago. It now runs intermittently and I would like to get it repaired. Can anyone recommend a repair company who's workmanship you have experience.
Bill
Bill
Harrison Speedometer just did my clock and cluster restoration. Top quality work. He will repair your original clock works or convert it to a quartz movement if you wish. Highly recommended by many.
http://harrisonspeedometer.com/
Dennis
Dennis
Received 1,044 Likes
C2 of Year Finalist (appearance mods) 2019
Do it yourself, it is easy, pull it out, take the nut off the + terminal, uncrimp the tabs (4), take a finger nail file, file the points, put a very little 3 in 1 oil on gears (none on the main spring) and put it back together, no need to take the face or **** off if you are not restoring the face.
ghec369 (03-13-2020)
Dennis
Dennis
Had mine done a couple years ago and it's still working fantastic. He also refurbished it and my cluster with all gauges to perfection.
You won't be disappointed...
RK
If you want to do the quortz movement it works well, but if your car is original and you want to keep it that way, I would not do it. It is easy to detect the change, You can buy the quortz movement kit, it took me about a 1/2 hr to do it for someone and he keep the original movement if he wanted to put it back in.
Dennis
Clock
Thanks for the suggestions on this thread. I so need to take off the glass and replace mine. I assume the **** is just screw on but I realize it also pulls out in order to adjust the time. So do I just need to hold the stem with some needle nose while I unscrew it? Don't want to mess it up as it does work but the glass has been scratched up.
Dave Z
It is far to easy to do. You can do it faster than packing it to send away for repair.
http://vettenet.org/midyrclock.html
