What is the LOWEST Idle speed your Generator will Charge at??
Here's a question I'd like to throw out there to all the C-1 guys, at what engine idle speed will your Generator produce enough juice to show a charge with all the lights ect... on (under load) assuming you have a healthy electrical system?????
I have been running some tests with the newly converted Solid State Voltage regulator and it seems I need a minimum of 850 RPM with the lights on and 700 RPM (daytime) no load to keep the Ammeter at "0". At 1000 RPM, I can run everything the car has and show a positive charge until the battery tops off.
Also, according to the specs, they call for 450RPM idle speed which I have NEVER been able to achieve a decent rate of charge at. Does anyone know why that number is so low??? Did GM mean for these cars to run at a discharge at idle?? Pilot Dan
I'm using the old mechanical regulator and mine performs just like yours. Mine idles at 750RPM and will show a slight dis-charge if I turn on the lights but will show a charge with just a slight increase in idle speed. It's been this way for 35+ years.
Jim
Jim
That was pretty much how I remember my original mechanical voltage regulator working in the past. I had read that resistance in a circuit (like a bad ground or battery drain when off) can also contribute to low charge at slow engine speeds. Don't think that is the case here though since I replaced all the wiring. Thanks for the reply.
Seems that's perfectly normal behavior to me...of course my original 270HP '61 will NEVER idle at 450RPM...
As far as the VR conversion, I like what I see so far. Hope it will be trouble free for a good long while. No question, it works much better once the Generator spins fast enough to supply the power.
Pretty much my experience having driven generator cars of all types for quite a few years. The cars weren't intended to idle until the battery is discharged...
No other opinions either way guys??? OK, let me pose this a different way, do the current restoration T-3 headlights (LL Wagner conversions) have the same resistance as the original T-3's??? I am wondering if the restoration headlamps could be drawing more power and therefore contributing to the negative charge at low idle setting. Thoughts????
Not sure what you're driving at. All the old generator cars I drove did not charge at idle. All you had to do was bring the RPM's up a little and you were fine. You would discharge with the "old " T-3 headlights at idle.
Received 1,843 Likes
There's not much more to say. Generator cars won't charge at low idle speeds. As the electrical load on a cars charging system increased, this became a problem and that's why alternators became standard equipment.
That's pretty much a thing of the past with alternators.
Charging output depends on the diameter of your generator pulley, engine speed "RPM's", condition of the generator, correct adjustments to the voltage regulator, condition and size of wiring. Here is a link that may help: http://www.42fordgpw.com/voltage.html
rustylugnuts
rustylugnuts
