My 65 383 stroker is running very rich, need help.
Old 10-22-2011, 09:28 PM
TXSTICK
TXSTICK's Avatar
Default My 65 383 stroker is running very rich, need help.
I have a 383 stroker with a Holley Street Avenger 770 cfm on it.
I do not know what jets are in the carb yet. I have not checked the timing but a comp cam tech told me the cam (I believe it is a comp cam XR282HR) likes about 12 deg adv. The car is very rich at idle and I have been told by someone who followed me it is very rich driving down the road.
(burns the eyes)
The car was orig in California at near sea level and is now at around 2800 ft.
What would be a good starting point for the jets front and rear?
I will check the timing and set the carb idle mixture screws this week with a vacuum gauge. But I an not sure if that is all it needs.
thanks
chuck
Old 10-22-2011, 10:00 PM
Dicecal
Dicecal's Avatar
http://www.lbfun.com/warehouse/tech_...rb%20Paper.pdf
Old 10-22-2011, 10:26 PM
vt65
vt65's Avatar
Chuck, I have the same problem but i'm running a 383 with a new 750 Holley, runs bad rich, always have to be at the back of the line, no-one wants to follow us, hope you get some good ideas here, getting tired of 7 mpg
Old 10-22-2011, 10:53 PM
TXSTICK
TXSTICK's Avatar
Thanks for the link.
chuck
Old 10-22-2011, 11:13 PM
mikem350
mikem350's Avatar
If its that rich..you probably have a PROBLEM w the CARB, not timing
Check obvious...is choke flap open???
Is pcv hooked up..most carbs are set up so they expect to see more air coming in via the pcv
also a leaking power valve will cause richness
use the same jets that shipped with the carb originally..Holley has about 100 years of experience here...I've used avengers and only had to tweek the idle screws about 1/4 turn each and NEVER had another problem
Old 10-23-2011, 03:29 PM
TXSTICK
TXSTICK's Avatar
Thanks, previous owner sent me an email and said the carb was adjusted during the dyno tune of the engine.
I will check for pcv and other items you said above.
thanks
chuck
Old 10-23-2011, 06:08 PM
65tripleblack
65tripleblack's Avatar
I do not know what jets are in the carb yet. I have not checked the timing but a comp cam tech told me the cam (I believe it is a comp cam 280H) likes about 12 deg adv. The car is very rich at idle and I have been told by someone who followed me it is very rich driving down the road.
(burns the eyes)
thanks
chuck
If you are using the stock coil and/or a weak one, you may have that type of problem because you are not getting consistent and complete burn. If you are fouling plugs, as well, there is the proof of the pudding.
Old 10-23-2011, 07:48 PM
TXSTICK
TXSTICK's Avatar
It has the Pertronics II Ignition, and I put in a Pertronics coil (45,000) about 5 months ago.
I have not pulled a plug yet.
Old 10-23-2011, 08:19 PM
claysmoker
claysmoker's Avatar
St. Jude Donor '09-'11-'12-'13-'14
If you are close to 3000' above sea level, go down two jet sizes both primary and secondary. I'm at 5K feet and the problem is even worse here. I drilled both the primary blades with a .090" hole and it helps lean the idle as well.
I'm sure these carbs come out of the factory on the rich side anyway, so you may have to go more than the two jet sizes. If you pick up an off idle stumble, you may also have to change the accelerator pump cam. I ended up with a black one.
Check the vacuum at idle. You may have to go to a smaller numerical power valve. I think those carbs come with a 6.5, and mine is much happier with a 4.5 at my altitude.
Good luck!
Old 10-23-2011, 08:43 PM
TXSTICK
TXSTICK's Avatar
Good luck!
Thanks, my friend who is a mechanic, also said it could be due to the higher altitude. It does stumble off idle. I will have to look at what is in the car after I do my last car show next weekend. I won't do another until Jan 2012. I don't need the car down right now.
chuck
Old 10-24-2011, 12:08 AM
Kensmith
Support Corvetteforum!
Kensmith's Avatar
Chuck,
The car was tuned in Sacramento, CA. Do not change timing as it is correct. If you are at 3,000 ft elevation it's the carb. Elevation will make a difference. If you were at 6,000 ft it would run like a 6 cylinder. Call Holley Tech and he will tell you what to do to tune the carb. Also, plugs are new like everything else on the motor. Vacuum advance can is also new so it has to be the carb and altitude.
Old 10-24-2011, 02:24 AM
Westlotorn
Westlotorn's Avatar
Received 1,273 Likes on 814 Posts
If it has backfired at all you may have just popped the power valve, it only takes once.
I would look at all 8 spark plugs and read them. If all 8 are black you know it is most likely carb issue and it sounds like it will be on this engine.
If some are clean and others are fouled it gives you a new direction to look.
Good luck.
Old 10-24-2011, 06:38 AM
mechron
mechron's Avatar
Originally Posted by Kensmith
Chuck,
hi ken, and hi turbo cat. if he is on here (thanks for the body drop, it was simple) on a holley if it jetted right the altuted it will take of itsef. at 6000 ft. it is all about the presuhure differentual thrugh the vintuiers.
as for the timing, who cares, my pantera is super fun.
Old 10-24-2011, 09:02 AM
Vet65te
Vet65te's Avatar
Received 1,032 Likes on 671 Posts
Chuck, the 770 Avenger has #72 Primary Jets and #75 Secondary Jets.
For comparison, the next size down Avenger, the 670 comes with #65 Primary Jets and #68 Secondary Jets.
Mike T.
Old 10-24-2011, 09:31 AM
TXSTICK
TXSTICK's Avatar
Chuck,
thanks Ken.
Westlotorn, It did a couple of times on the way out from Calif.
The coil was going TU. It finally did about 50 miles from my house.
I will check the power valve and my change it like claysmoker has suggested.
Vet65te I did read last night (holley manual on line) that for every 2000 ft of increased altitude the carb jet size should be dropped 1 size.
Thanks everyone!
Chuck
Old 10-24-2011, 09:54 AM
Vet65te
Vet65te's Avatar
Txstick - I believe all the Avenger Carbs come with what Holley calls their Power Valve Saver built into the baseplate. Of course, since you're probably going to be in there anyway to change jets, you might as well verify the power valve too.
Mike T.
Old 10-24-2011, 10:00 AM
TXSTICK
TXSTICK's Avatar
Mike T.
Mike,
Correct, I also read that. But I might need to change it to a different one anyway per claysmoker. The Holley manual says to check the vaccum with the engine warm and at idle. Half the vaccum number, and if even go down to the next odd size (8 would use a 3.5, 9 would use a 4.5). If the vaccum is more than 13 then the stock 6.5 will do fine. The wrong one can cause a rich condition.
To My 65 383 stroker is running very rich, need help.
Old 10-24-2011, 10:16 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Def on the rich side you could run that on a 68 all day no need for more than a 70 jet.
The 1/2 vacuum powervalve thing, no
You should be able to run fine on the stock 6.5
Old 10-24-2011, 11:32 AM
Vet65te
Vet65te's Avatar
Chuck, I'll be interested to hear what your vacuum reading comes out to at your altitude compared to what it was for the PO at nearly sea level. I expect to have to do even more 'carb-jet-tweaking' when we finally move from our current location in Northern California, which is maybe a hundred feet above sea level, to our lot in Prescott Arizona which is roughly at the 5400 foot elevation.
Mike T.
Old 10-24-2011, 11:48 AM
TXSTICK
TXSTICK's Avatar
Mike T.
Mike, I will post it next week. I am not going to work on the car until after this weekend. (Last show to go to) But I bet I will have to drop the jets down to around 68's on the front and a couple sizes on the rear.
Chuck
Quick Reply: My 65 383 stroker is running very rich, need help.
