Home made ramps ?
Old 11-14-2011, 02:21 PM
csysman
csysman's Avatar
Default Home made ramps ?
Im in a condo now and was looking to build some ramps to be able to clean the under carriage of my c2 , and may be do some minor service ie.oil changes and such . bought some ramps but either they are not raising the car high enough off the ground or I need to go in a diet... Im guessing the second option is correct - any pics of some home made ramps and the details or plans would be awesome. saw some on you tube called my lift stand ... but cant find where to purchase (myliftstand's Channel - YouTube)
Thanx in Advance
Charlie
Old 11-14-2011, 08:43 PM
Bluestripe67
Support Corvetteforum!
Bluestripe67's Avatar
Received 2,127 Likes on 1,466 Posts
Check out DiscountRamps.com good selection if you don't feel like making your own. Dennis
Old 11-14-2011, 08:52 PM
Hitch
Hitch's Avatar
The best way is to buy a set of jack stands along with two floor jacks. Then you can jack both sides and then put the stands under neith. JMO..
David
Old 11-14-2011, 08:53 PM
nassau66427
nassau66427's Avatar
Location: going faster miles an hour...with the radio on in browns mills new jersey
You could try a search here.
There were some good looking home made ones posted a couple of years back.
Was it forum member "Hitch"?
Old 11-14-2011, 08:55 PM
Redbird
Redbird's Avatar
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
My 40 year old wood ramps are made out of 2"x6" and 2"x4"s. Just eye- balled the slope if I recall.
nassau66427
David
Talk about timing.
Didn't you make some?
Old 11-14-2011, 09:35 PM
Hitch
Hitch's Avatar
Originally Posted by nassau66427
Talk about timing.
Wish I could take the credit it was another member in the C3 section. I just posted it over here.. lol
David...
Old 11-14-2011, 09:39 PM
Jalopy31
Jalopy31's Avatar
I don't have any ramp plans that will help you out, but have thought about building a set from wood as well.
I have a buddy with a super-low '32 Ford 3-window coupe, and he made a nice set of wood ramps for it. One element I liked was that he made the bottom layer of the wood ramps from thin (about 5/8" thick) plywood that sticks out about 12" from where the incline of the ramps starts. He did this to keep the ramps from scooting on the floor as the front tires hit the inclined portion of the ramps. The weight of the car is on this plywood portion of the ramps before the front tires hit the inclined portion.
I thought this was a smart approach that may help you with your design.
Old 11-14-2011, 10:10 PM
UberLegend
UberLegend's Avatar
Old 11-14-2011, 10:22 PM
wombvette
wombvette's Avatar
Just be careful. They are one of the most dangerous pieces of equipment you can use. I have had two acquaintances killed using them.
Old 11-14-2011, 10:27 PM
GreaseMonkey
GreaseMonkey's Avatar
PA Events Coordinator
I just built some blocks to put the '64 up on. I wasn't happy working under the car on jack stands, and they were a PITA trying to figure out how to get them under the front end of the car with the Hooker side pipe setup. I have some "wiggling to do under the car and really didn't feel safe with anything I had, and didn't feel like dropping close to $100 for something I wouldn't still feel safe under.
I don't have any pics right now, but can take some tomorrow and post tomorrow night. I have not put the car on them yet either.
I took scrap lumber I had in the basement and built some 21"L X 12"W X 10" H wheel blocks. Started off with some pressure treated 6" X 6" stock, and built from there. May make more sense when I get pics posted.
It will be some interesting work getting the car on them, but I will feel more safe under them than on jack stands.
Old 11-14-2011, 10:41 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
I made these about 30 years ago, and they still work great. I think I got the plans out of Mechanix Illustrated or Popular Mechanics. I posted the pics of them about a year and a half ago, maybe longer. Here you go....
Old 11-15-2011, 08:01 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
You should just invest in some Race Ramps...they get my '61 up high enough for oil changes (and even to change leaf springs)...weigh next to nothing and are probably safer than something you whip up in the garage. It costs a little money but so does a hospital bill.
Old 11-15-2011, 08:14 AM
csysman
csysman's Avatar
Thanx to everyone for all the replies I like leaving the car up in the air with the wheels supported and not hanging when we go down to Florida for the winter ...
Happy Thanksgiving to everyone
Charlie
Old 11-15-2011, 10:13 AM
66since71
66since71's Avatar
I'm with wombvette on this. Cars roll onto ramps. They can just as easily roll off, with you underneath them. I also know of someone killed using ramps. As uncomfortable as I am with jack stands, I've never heard of a fatal accident using them.
Harry
Old 11-15-2011, 01:50 PM
Frankie the Fink
Army
If you are not going to pay attention to what you are doing either one can kill you.
I work on jack stands only when unavoidable...otherwise my ramps are used.
With the rear wheel "cribs" used as in the picture above the car isn't going to roll anywhere.
Old 11-15-2011, 02:32 PM
TC233
CF Senior Fox Bat
TC233's Avatar
Thanx in Advance
Charlie
http://corvettec3.ca/ramps.htm
I am building the ones at the bottom for now, too late to mod the garage this winter and put in a 4 point lift.
To Home made ramps ?
Old 11-15-2011, 07:04 PM
DansYellow66
DansYellow66's Avatar
Received 2,620 Likes on 1,952 Posts
Yeah, I have a set made out of 2x8s for the sides and a middle rail and plywood on the top surface. I put a end section of plywood on also that sticks up a couple inches to create a stop to prevent going over the end. I custom built them for the new 85 Corvette I bought that would not go up steel ramps because of the low nose and spoiler. They are a little heavy but stable.
Old 11-16-2011, 10:59 AM
0Fred@ReverseLogic
Former Vendor
Fred@ReverseLogic's Avatar
You can also check out one of the forum sponsors that sell ramps.
Old 11-17-2011, 08:51 AM
Mike Mercury
Mike Mercury's Avatar
herer's the ones I built:
www.tim-yvonne.com/mikemercury/ramp.htm
Quick Reply: Home made ramps ?
