65 body is off the frame
Here she is hanging in the air. The #4 body shims were nothing but rust. That is probably why my doors had a big gap at the top.
Here she is setting on the body dollie.
Now it's time to take a close look at the frame.
Received 2,127 Likes
Your cross beams on the lift look real sturdy. If I ever do this I'll use the same method. Dennis
Like you, I am considering removing my wheels before lifting the body. Did you have any extra pairs of hands to help when you lifted the body? I really, really need to get the body off my car. I'm kinda high-centered until I get it removed.
Good work.
Good work.
I did have my wife help me by lifting the rear a little to keep things balanced.
Two things to keep in mind when doing your body off,
1. Have someone keep an eye on the clearance between the #4 body mount on the frame and the rear of the rear wheel opening on the body. The clearance is real close.
2. Originally I had the dollie wheels mounted on the four corners. Because of the way my engine hoist lined up with the body, I had to move one of the wheels on the dollie to clear the legs on my engine hoist.
So someone noticed that I went from a 2 x 4 wooden lifting jig to a 2 x 2 x 1/8 steel tubing one. Thanks to comments from here on the Forum I rethought that one.
Received 1,762 Likes
