Gear ratio
Cruising
Gear ratio
Gear ratio,
Hi guys when driving my 66 vette 427, 4 speed the cars rpm is running around 3600 rpm at hwy speed. I am thinking of changing the gear ratio and from what I have read sound like going with 3:36 or 3:55 gears are good cruising gears. Anyone out there running these gears? How does the car perform of the line and what RPM are you running at on the hwy.
thanks
thanks
Received 2,112 Likes
Gear ratio,
thanks
thanks
Stock 27" tires and 4.11 3600 rpm at 70 mph
3.36 will drop you to about 2900 at 70 mph
With the BB you'll still be OK off the line
http://www.angelfire.com/fl/procrastination/rear.html
Transmission ?
If you have a wide ratio Muncie then a 3.36 ,
close ratio then a 3.55. The 427 has the torque to pull
it.
I use a 3.36 in my small block 355 with a wide ratio.
Get an 11 inch clutch and you will be fine.
2800 rpm at 70 mph.
Ray
it.
2800 rpm at 70 mph.
Ray
I have 3:55 stock gears (AZ) and 27" tire diameter in my 427 L72 and running around 2800 at 100 kph (62mph) and I wouldn't go any lower with a M21 , a little sluggish off the line in city traffic but otherwise ok , but a lower fourth gear ( M21Y) would be nice though. It's a 450 rpm drop in fourth gear.
I'm running 3.55's in our L78 with relatively tall tires (70 series radials), I don't think 3.36's would be a good choice if you want decent acceleration. I considered 3.73's during during the rebuild, but I'm happy with the 3.55's.
I went to a wide ratio 4 speed and a 3.36 rear on my '66 big block. I'm perfectly happy driving in town in 3rd gear and it runs great on the highway. Acceleration might be slightly less than the 4.11 rear that I originally had, but not enough to make a difference. With the higher gears, my 496 bb can really move. Good luck.
My L36 has 3.36 gears 4 speed 215/70/15 tires..
Probably 2800 rpms at 70 mph... plenty of power in all gears..
I sure did wish for a 5 speed when I was trying to keep up with the new corvettes when I drove from San Antonio to Corpus last September for The Lexington aircraft carrier ...Gave that up quickly! Ha!
too many rpms at 80 mph or more ... It will do it with no problem but don't like to go over 70 for too long a period.. No sense in it...
Car never runs hot... even in 103 degrees in bumper to bumper traffic.... Had it down here for 6 years... (knock on wood)
Cheers, Zale
Cheers, Zale
Cheers, Zale
Cheers, Zale
That amazing Qtr mile time that Car and Driver reported in their 66 - 427/425 road test back in 1966 (12.8 sec at 112 mph) was supposedly with a 3.36 rear. Yeah, I know - you can't believe everything you read.
those skinny tires..... Ha!
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
A 5 speed would give you the best of both worlds.
JIM
JIM
I think you will be unhappy going from a 4:11 to a 3:36....especially if you have a close ratio tranny. I think a 3:55 would be a good compromise gear.
My 66 427/425 came with 4.11 and close ratio trans. I put a 3.36 in it 12 years ago plenty of power in all gears best improvement ever made to that car.Still have the restored 4.11 if I have to go faster half a days work.
Mark
Mark
