How is the original Rochester fuel injection for regular driving?
#41
Received 1,843 Likes
I have had issues with E10, several years past before I understood the necessity of keeping moisture out of the fuel. You get some moisture in the fuel, it'll mix and run on through but maybe not really well. You get too much moisture in your fuel and the engine wither won't run, run poorly and/or, sooner or later, you'll have a wad of snotty looking glob hanging around the main jet(s) in your carburetor. The first sign of this is you'll notice (small engines) you have to run the engine with the choke partially on. The next sign, the engine will eventually stall.
It's been my experience, when E10 evaporates, it leaves little/no deposits behind. If it does, it probably had water in it and that's what makes the gooey deposit.
I just started up a 30 year old weedeater this morning that hadn't been run in about five years. Sat empty of fuel. I put fresh E10 in it,(no primer bulb) pulled the starter rope four times and it fired and ran perfect. Fired my Sportster up the other day. it hasn't been run since last fall. Fired right up and idled fine. I have cars that don't get started but every couple years but they start run with no problem.
That's my general experience with E10. Just keep the water out of it and no problems.
#42
You are not confused at all - that is my story, but I wasn't sure what you meant saying if it runs - grab it? I think I need to be VERY careful this time!!
#43
all kinds of expert opinions here, especially those that never owned one as new or at any time are probably the best.....
there cute aren't they and everyone should own one
wait until one of the new FI owners hydraulics the engine, now that's a whole new experience that was never mentioned and almost uniquely limited to FI Vettes......
#44
I have no isssues as long as the gasoline I have in storage is kept in sealed containers to keep the alcohol from attracting water.
#46
Rochester FI
Mine was the original Rochester but I found out the car was not at all as presented to me. IE having original motor etc but just a restamped engine to spears to be original and pump up the price. I made a deal and returned that Corvette at considerable cost but now have an authentic all original 62 with all original parts including engine. But not fuel injection. I doubt there are many truly original FILE engine cars out there because people bought that hot engine to go and they were used pretty hard. Watch out for fakes!!
#47
I think it's better said to not pay extra for "fakes", whatever fake is.
My '63 is a fake but I didn't pay extra for the car, I just built it that way and it runs like a demon! Shows good as original too!
So, the only difference I can see between a real one and a fake is about $20K on the price of the car and like you said, probably most of the ones remaining in the market are "fakes". Whatever that is.
