'66 shifter options?
Received 1,843 Likes
It is a late 66.....why in heaven then was this the first that was modified on these cars....
I have driven slews of original cars from the 60's with 4 speeds....even some chevelles with Muncie's in them.....the shifter feels fine....you just can't overshoot it at all....
And if I drive like that....I will pay the consequences of it breaking.....
Corvettes were not built to be babied....and the day I baby mine will be the day someone else can own it. If you baby yours-fine. I do not.
I don't powershift at every light.....but I don't drive like grandpa-rehaw
either.
What exactly do the rear end gears have to do with anything?
I am confident the parts in my car will hold up....they have for 4500 miles of me "driving" like that. My car was built to be driven....and it is.
Jebby
either.
Jebby
In my neck of the woods, there weren't many changed over in the first few years of the cars life anyway. When they became "used cars" and the kids got hold of them and started drag racing, some were changed to Hurst. If you're gonna' race, the Hurst is the way to go. If you're gonna' cruise, it's a waste of money vs. a good, tight, stock shifter. Also, you gotta' like the notchey, high effort of the Hurst to put up with it. I don't, and yes, I've owned a number of Hurst shifted cars.
As far as the '60's muscle cars and the stock Muncie shifters, those things were all junk as soon as they took the first hard shift through the gears. That wasn't the same piece as the Corvette shifter. Believe me, I have spent my time laying on my back at the side of the road, fiddling with the shift levers to get the tranmission unlocked. Finally fixed it by reinforcing the shift lever housing with 1/8" metal stock welded to it. No more trouble.
Changing to a Hurst Shifter back then was because of the pimply faced boys, just out of puberty that owned the cars had such a unnatural fantasy toward Linda Vaughn, they somehow seemed to be in touch with her if they had the Hurst shifter in their hand. Kinda' like rubbin on Linda.!
I told ya', if you want to thrash your car, go ahead, you need the Hurst. Otherwise, a stocker in good shape, well adjusted, well lubricated works perfectly.
The OP doesn't sound like a racer, he just wants to ride.
Dr. Detroit
Received 3,892 Likes
Well said!
Jebby
Jebby
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Received 1,857 Likes
Look at the 1-2 and 3-4 shift levers on the side cover - if they have two holes (one at the end, and another one closer to the pivot), like the one in the photo below, you can connect the rods to the holes closer to the pivot to set it up as short-throw.
Dr. Detroit
Great photo!
I can see exactly why I get locked up in a 2-3 powershift now.
maybe I could weld my own stops on
Jebby
Jebby
Dr. Detroit
Good idea....thanks for posting it.....I sometimes don't elaborate my thoughts from the wasteland of my mind
Hey it is free!
Jebby
C2 of Year Finalist (appearance mods) 2019
I just noticed you put a (?) after smile. Sorry.
Dr. Detroit
It got locked in third last night on the way to cruise night at the burger joint.......
Hurst is going in soon.....this sucks....
Jebby
Jebby
By the way, why are you power shifting on the way to the cruise? Trying to get a front row parking spot?
#33
Dr. Detroit
Jebby
#34
St. Jude Donor '09
bushings work in a muncie or need to replace some parts-----thanks ------jimbo
#35
Yes, they will work. I am currently running the Hurst shifter with the OEM shifter arms. I have the pit pac bushings in this set up and have had them in for years.
#37
St. Jude Donor '09
i like the looks of the curved hurst shifter you have in your car- i was thinking originally of putting in the hurst which looks exactly like the original but not sure now-hung up between replacing original muncie, putting new bushings and link pins in muncie, or pulling it and going with a version of hurst-
#38
#39
Received 1,308 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
#40
