Overheating 65 small block
Old Jul 17, 2012 | 05:57 PM
Jerry Morris's Avatar
Jerry Morris
Default Overheating 65 small block
The folks here have helped me on various occasions. This might be of help to someone. My small block 65 was overheating at traffic lights or when idling after a good run. It was fine as long as it was moving. A DeWitts' radiator with an electric fan seems to have solved the problem. I am hoping this might be of use to someone who was in my situation.
Old Jul 17, 2012 | 06:00 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the new rad was all you really needed. the electric fan was over kill. but glad your problem was solved
Old Jul 17, 2012 | 06:04 PM
Jerry Morris
got new rad, not DeWitts, did not do it
Old Jul 17, 2012 | 06:06 PM
Rons65's Avatar
Rons65
My 65 still overheated in traffic after I installed a new DeWitts - then, I added the Spal fan and took care of the issue - however, mine was a A/C car which did not help, but surely was needed here in AZ!
Nice to see you solved the issues - nothing worse than overheating when you are out driving your midyear!
Old Jul 17, 2012 | 06:09 PM
Jerry Morris
mine has ac too. It was 95 here in Boston today, not Arizona, but hot for us.
Old Jul 18, 2012 | 07:05 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Maybe in Penn. with no a/c.
Here in Texas the stock system needs it. Mine is text book "Dewitts"correct and in new order. The electric fan helps when traffic comes up and the a/c is on. It also does wonders for short stops. Cools the carb down. Makes for easy hot re-starts.
I will add, the stock C2 (proper radiator and clutch fan) cooling system is excellent.At temps under 90 degrees it's rock steady at 180 even with brisk driving. But there are times it needs help.
Old Jul 18, 2012 | 11:15 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
That describes my 65 ac car, same exact setup and same results. 90 plus the car needs an electric fan.
To Overheating 65 small block
