Aftermarket frame experience
4th Gear
I plan to replace the rusted frame on my 63 coupe with one of the aftermarket frames. I want a complete roller & will do the body swap myself, as well as installing a crate motor & 5 speed. Does anyone have personal experience, pro or con with any of these frame builders, SRiii, Street Shop, Jamison, Collier, etc.
My ideal car will appear more-less original, with wheels & tires that look more period correct than modern; not big rims/ultra-low profile tires.
What can you tell me that I should know before I start on this project?
Thanks your help.
Thanks your help.
I know this doesn't answer your question but if you want to keep the car looking stock and don't want to go with all the new suspension upgrades why not just find a good used frame?
Received 1,856 Likes
Thanks your help.
Thanks your help.
www.vetteproducts.net
I have bought several SRIII frames over the last 10 years, and have never failed to be completely satisfied with all of them. Street Shop makes a nice frame as well, especially if you want a rectangular tubing chassis rather than a round tube one. All that being said, as John said, the lowest cost alternative is to put a stock replacement frame under the car. It is all about what you want and how much you want to spend.
Regards, John McGraw
4th Gear
Thanks for the input. The reason I want a roller is mostly a time issue. This had been a race car and everything from the motor to the diff is non-original and worn out. I am afraid if I rebuild everything the project will drag on forever, and I really want to get it on the road. Since nothing in the car is original there is nothing worth saving, so I thought a complete roller would be a good solution. I also admit I kinda like the idea of modern brakes & steering, although I love the feel of old school carbureted V8.
Unless you just have an affinity for tubular aftermarket frames (which will set you back about $12,000.00 - $15,000.00), why not simply replace your rusty original frame with a brand-new GM-licensed stock frame from Vette Products of Michigan? They're about 1/3 of what you'll spend for a tubular frame.
Also Neil is nothing but Honey love and peachs all wrapped into one!
An after market chassis using c4 suspension is probably what your looking for. The photo shows a 65 with a Street Shop chassis and c4 components.
The wheels are 17" and the car pretty much has a traditional looking appearance.
Nev Williams (10-15-2019)
If you can do a body swap and a 5 speed you can certainly move your suspension/brake parts (replacing stuff as needed) to a new frame.
I'd say go with JohnZ's advice...
Thanks your help.
Thanks your help.
Here's mine... I've yet to see another old school motor in a tube chassis.. but it's what I preferred.
Also, keep an eye out for a complete original chassis. I've seen a few for sale over the years.. I mean afterall, I sold mine... but it was slightly bent..
Thanks your help.
Thanks your help.
