Whitewalls
Whitewalls
I purchased a set of wide whitewall tires from Coker. I unwrapped them, put them on the car, and can't seem to get the yellowish color to turn white.
What is the best thing to use on this.
I'm not trying to be a smarta$$, but I would send them back and buy from Diamondback.
Received 2,130 Likes
2015 C2 of the Year Finalist
Hate to say it, but I can confirm this. 8 cars. 7 with white walls, 2 with Coker wide whites. Time will turn them yellow to brown. I use hot wet SOS pads with commercial white wall cleaner I buy from a car wash supplier (although Westly's will work). I rinse with hot water, and I do it again. This will make them acceptable for most of the season, but you will be doing it again as soon as that fresh layer oxidizes like the last. Mine began to yellow long after the first year so no returns. If yours are yellowing already they are probably old stock, or they just suck. Never used Diamondback (although I will) as I have heard good things. One tire should not cost the same as a TV set & turn yellow.
Dan
Back in "the day" we used SOS pads, Comet or Ajax cleaner with bleach and a brass bristle brush, and/or Wesleys Whitewall Cleaner.
Any or all should do the job. Then apply some name brand tire protectant. I prefer Meguiars #40 Vinyl and Rubber Protectant, but there are many others.
All tires now have DOT date codes. Check yours to see the age of the tires. Decoding info is on the internet, just Google "DOT tire decoding", or something similar.
Larry
Larry
Larry
Larry
My wide white Diamond Backs are 3 years old now and snow white. I just use a little 'scratchy' pad and VERY rarely Wesley's Bleach White. DBs have a butyl layer under the white wall which prevents chemical 'leeching' - the number one cause of yellowing of white walls. http://www.dbtires.com/cleaningtips.html
I bought corkers, gave them to a buddy after about a year due to yellowing (would not come clean with "any" cleaner). Had diamond backs ever since
Have DiamondBack wide whites on my '37 Chev 2 dr sedan, six years now. This car gets driven.....still white!!! Only use Simple Green and a light scrub pad...really works. In-laws have Coker wide-yellows on their '57 Ford convertible, and are too tight to replace otherwise good tires, but totally disappointed with Cokers and will go with DB next time.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,326 Likes
Diamond Back, period. 6 + years old.
Several people in our local club have had problems with Coker Tires with yellowing but one with a tread seperation at 65 mph.
The Wesley's Bleach White as we use to know it has been pruchased by another company and its no longer what it use to be.
a few years back a freind here offered me a new set of cokers he had .great price , when i arrived to buy them to both of our dismay he pulled them from storage .the white walls had been stacked and black leached into the white wall , he could not remove stain . I ended up buying black walls that day form local tire shop , I know now DBWW next time I retire up !
