Missing some braces from my exhaust system
CF Senior Fox Bat
I was just going through a vendors pictures for a 63 exhaust system.
My car never came with 38A&B +38C&D and possibly 42?
Does anyone have a picture of the underside of their vehicle showing these parts?
Received 6,928 Likes
2015 C2 of Year Finalist
All mid years with under car exhaust got those parts. That part is were the pipes were joined together and clamped to the hanger that is bolted to the trans cross member
CF Senior Fox Bat
Thanks.
63's used the hanger shown here in the middle, 2" size for 2" exhausts, 2.5" size for 2.5" exhausts.
They have the conveyor belt strapping hangers in the middle.
Refer to the pics.
Chuck
Chuck I never knew that. Thanks. Anther one year only part I see
Received 1,843 Likes
CF Senior Fox Bat
Going to have to crawl under the car this weekend if I can get under it. Pretty sure I am missing one of those items, not sure which one.....memory fail
The #42 item, I believe, is a spacer IF the car had side exhausts.
It goes between the trans and the rear mount, raising the trans XX amount IF the under car batwing bracket isn't there.
Chuck
Chuck
Its not called out for in the 67 AIM under U14
My 69 is a factory side exhaust car, and it does have that spacer.
IIRC, the spacer is about 1.25" wide, 5" long and ??? thick, maybe 3/16".
Supposedly it was to compensate for the change in the engine/trans/driveline angle if the under-car hanger wasn't used. The hanger raised the tail of the trans by XXX amount, and the spacer was supposed to compensate for that on a side exhaust car.
I think it's splitting hairs.
Chuck
Chuck is it in you 69 AIM
Former Vendor
I have an original hanger/clamp assembly for the 2 1/2" pipes.
geopar@gvtc.com
