Knock off cone won't stay on
Received 1,308 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
I'm beside myself with this one. Of the four cones, only one won't stay put. No sooner than I think I secured it with silicone, the same as the other three, it loosens and rattles.
Need some help here, please!
I doubt it's the problem in your case, but make sure the wheel is oriented correctly on the hub. If you have the small holes over the lugs, the spinner won't tighten as far down on the threads and there is extra space between the hub and the inner edge of the spinner that should butt up against the cone. Are you putting the silicone around the side of the cone that touches the wheel, or at the other end near the spinner, or both? I haven't had the issue, but I'm just trying to think what the difference would be in the one wheel.
Instead of silicone I used 3M dum dum putty behind mine. Can't see how they could loosen up with either however as long as the silicone is cured out.
I'll let you gents know how it comes out if you don't mind.
Try this... use florist putty, very easy to work with, and will hold up to any type of weather.
Bruce
I was told to lay a couple of beads of silicone on the inside of the cone and let it dry for a day or so. That way they would not stick to the wheel and when compressed they would not rattle. Worked for me and has been for a number of years now. Don't know if it is correct but it does work.
