universal neutral safety switch for a turbo 350
I'm a little confused (Ok alot) on what type of universal neutral safety switch to buy for my 58 with a automatic turbo 350 ?
Before I replaced all my wiring harness the wiring for the neutral safety switch was by passed (not me) because the transmission had no safety switch. Did a turbo 350 originally have a neutral safety switch that attached to a floor shifter?
Any pictures of a install of a neutral safety switch on a turbo 350?
Received 6,928 Likes
2015 C2 of Year Finalist
I think NSS became standard some time around 1964 or so for all GM autos. turbo 350s did not come out until 69? so any NSS should work.
Turbo 350
I know the 68 had a 350 turbo and the Chevelles also had the 350's. The Chevelle had the switch in the shifter and it was part of the harness. I can check my AM for my 68 and see if the wiring for the switch is in the harness. Jerry
Maybe this? It mounts to the trans so you can use any shifter.
http://www.painlessperformance.com/w...rchField=80175
The Manual.....
http://www.painlessperformance.com/Manuals/80175.pdf
The Manual.....
The Manual.....
The Manual.....
