C1 front sway bar
C1 front sway bar
Anyone know how long the front sway bar sleeves are? How about pictures of one installed? I have something funky going on. I have Binding on the front passenger side.
Mike
Mike
Well it's not the swaybar. I unhooked it. I think the angle is wrong but it's not the issue. I guess that it's really not binding but the pass front is very stiff compared to the drivers side. I can barlely squat it . Just pulled front shocks. They are not the issue either.
I'm guessing I have a weak drivers spring. With no swaybar or shocks I can lift drivers side much easier than passenger side same with compression. Also driver front sits 1 inch lower than passenger side.
Only noises now is just the springs. I don't know how long it's been like this. It sat for 13 yrs till last summer drove it a couple times trying to work out the bugs. When The nose would drop after shifting or a hard accelerated run it woul dart pretty bad. So I parked till now. That's when I found that the pass side is much stiffer.
St. Jude Donor '07
well, you disconnected the shocks and the sway bar, and there are no 'ugly' sounds like an upper/lower a-frame seizing up, they that leaves the springs... how do the rear springs look? if one of those is broken or sagging, then the opposite front corner would be higher.
Bill
Bill
