Does any know of dual switchback LED`s without the solder spots on top of the socket
I had to change one 1157 LED bulb-Dual intensety 18 SMT LED tower LED`s that i use for daytime driving lights and amber turn signal
On regular bulbs there are no solder points on the socket but on the LED`S there is 3 small solder spots on each LED bulb.
The solder spots stops the LED bulb from going all in on the park light on the car so i have to sand off the solder spots(used a nail file)to make them work
I had to sand off the solder spots when i converted to LED daylight driving light/turn signal light 3 years ago as well
The reason why i had to replace a LED light is because the LED came loose from the socket because i sanded off the solder spots i think
Any here know if you can get 1157 LED lights or is just the LED`s without those solder spots?
You can see one of the solder spots on the socket on the LED to the left and no such solder spots on regular 1157 bulbs
Roger,
If worst comes to worst, so you can have DRL's those bulbs will fit in atermarket replacement turnsignals without having to grind solder down.
Pæren tårnene er limet-limt til kontakten. Sliping av loddetinn ikke føre til at problemet med pære tårnet løsner fra kontakten.
Du ønsker kanskje å prøve disse som erstatning.
http://www.superbrightleds.com/morei...ed-tower-/814/
Jere. I thought that the LEDs i ordered now might not have the solder spots but they did
The LED light that Avispa posted the link to looks like an easy fit
1157 LED Bulb - Dual Intensity 45 SMD LED Tower
Here is a link to a film so you can see how the LED daytime driving lights and amber turn signals looks like on a C2
http://s414.photobucket.com/user/MrT...f204a.mp4.html
Roger,
I looked at the link posted for dual color LED lights like you and I have last night. I could not find white/yellow dual color bulbs, listed on the website.
Did you find dual color yellwo/white LEDs, that I missed?
Jere. I bought the LED`s(White/Amber Switch Back TurnSignal 60SMD LED Light 1157)on ebay.
There are plenty of rrom using the LED`S in the park lights
Note that this LED\`S have the 3 small solder spots on top of the socket that you have to file off some(i used a nail file and that worked great)
A metal nail file that is
You do not have to use resistors or anything like that. I just changed from regular 1157 bulbs to LE`s and it worked at once. If you are using LED tail lights you might need a LED relay
Link to the LED`s:
http://www.ebay.com/itm/White-Amber-...:L:PMR:US:1123
Here is another link after i searched for White/Amber Switch Back TurnSignal 60SMD LED Light 1157 on ebay
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
If you search for White/Amber Switch Back TurnSignal 60SMD LED Light 1157 using goggle you will also find a lot who sells them
Link to the LED`s:
65air_coupe. The running lights comes on when you put on the park light
I have had it like this for over 3 years since you have to use running lights in daylight here in this country.
If not there is a hefty fine
The owner before me back when i bought the car had extra lights under the front bumpers. Not pretty so that was the first thing i took off the car
isac. I did search for dual light LED`s both in Norway and Sweden but i did not find any like the ones on the picture that you found
On the link below is the dual LED`S that SuperBrightLeds.com have
http://www.superbrightleds.com/searc...0color%201157/
Anybody that have this in front and also use LED brake/tail/turn signal lights? Ids so i suppose you need a relay for it to work?
On the pic you have the dual light LED bulbs that I have in the park/turn signals in my car and they work great , they fit and works great as tail / brake lights too but you'll need a new LED flasher if you do that.
