radio speaker w/air
I have an air car but i think the dash speaker are the same
Have you checked the site below?
http://vintageautoradio.com/
Link to the dash speaker below
http://vintageautoradio.com/index.ph...mart&Itemid=67
Here is a picture of their dash speaker
I don't think you really mean 10 AMP speaker. You need a 10 OHM speaker with transformer. Here's a pricey one on ebay:
http://www.ebay.com/itm/Rebuilt-Original-1963-1964-1965-1966-1967-Corvette-Speaker-/281171603911?fits=Year%3A1967%7CModel%3ACorvette&hash=item41772231c7&vxp=mtr
Received 1,857 Likes
Don't even THINK about going anywhere but here for an electrically correct midyear radio speaker:
http://www.turnswitch.com/
Air/non-air SAME speaker. And this 10 ohm speaker is the best available. It will make the best sound for an original midyear radio IMHO, it sure did for mine.
Received 1,044 Likes
C2 of Year Finalist (appearance mods) 2019
Attachment 47737718
Received 6,943 Likes
2015 C2 of Year Finalist
You do learn something new everyday. There is a speaker for factory Air cars, it is about a 3/4 of an inch smaller in length to fit the air duct under it, no one makes them, I found one in my attic of my garage and I am taking it to Carlisle Fri. to drop it off for a recoaning
The AC speaker for sure is lower than the AC speaker
I put a non original speaker in my AC dash and there was no problem in doing that(a little tight where the center duct is)
Although the original a/c speaker is flatter, a standard speaker will fit with a little modification. I was unwilling to spend the big bucks for the correct a/c speaker. The center air duct is the culprit when trying to fit a standard speaker. I was able to bend the metal portion of the speaker into a slight curve so it would fit around the center duct. It takes a little trial and error and is much easier with the dash completely disassembled but it can be done. If you are going aftermarket make sure it is the right dimensions for an air car.
There was no change in sound quality. It sounds just as bad as a standard speaker.
Alternate parts used with other options are seldom shown in the A.I.M. option sections; normally there's a "non-illustrated parts" sheet that refers you to the "Engineering Parts List" for alternate part numbers.
Larry Phipps (04-09-2022)
