Upper Bolt On front Spindle
Any techniques to torquing the large 11/16 bolt that goes through the metal front dust shield and caliper bracket with spindle assembly OUT of the car? Was able to achieve the 50-60 lbs of torque for the 2 smaller bolts; but, having problems achieving 75 lbs for the large 11/16 bolt being awkward to hold onto. Had no problem removing it because it was significantly under torqued.
Should I wait until the spindle assembly is connected back in the car to finalize torque requirement?
1966 application.
Thank you.
1966 application.
Thank you.
Received 2,126 Likes
Yes, mount it on the car and put a drop of thread locker on it…torque it! Dennis
