Dash repair South Florida?
Hey guys,
Anyone know of a decent dash repair place in South Florida? I just bought a car and the driver's side dash pad has a crack in it. Instead of replacing it (won't match the passenger side, need to remove gauge cluster, glove box door, radio, radio side panels, etc) I would prefer to simply have it repaired. I know they do this, I just don't know of a place in South Florida. It's not an NCRS car, I just bought a really nice (looking) driver....(I won't get it until next week). Any help is appreciated, as always.
ARA
ARA
I don't know of a place but you should know that many such cracks are due to the failure of the underlying supportive material and degradation of the the top vinyl. You could get this crack fixed and get several more very quickly in the Florida heat and sun. Also, once you are far enough into the replacement of the driver's side you are 98% of the distance to also replace the passenger side....then they'll match just fine...
The trick is to pull the whole dash...not that bad a job at all...then everything is right in front of you...
There are many guys who make their living making calls to various new and used car dealerships. They do repairs on trade-ins.
They repair rips in vinyl and leather, holes in fabric upholstery, damage to carpets, vinyl roofs, .. etc.
Chuck
Chuck
cracks can be repaired. this car is a nice driver, not an NCRS car so I really wanted to avoid drilling the rivets and replacing the pad as I do not have any matching paint to paint the tabs with if I replaced it.
I got a name from my Lexus dealer a few years back. My wife shut the passenger door with the seat belt in a bad spot and made a small tear in the leather on the door panel, hard to see but I knew it was there. The Lexus dealer suggested we try the repair. It was great I couldn't find the spot knowing where it was, perfect match and not expensive.
I just Googled it and found these: http://www.qualityleatherrepair.com/
http://leatherrepairmiami.blogspot.c...er-repair.html
Hello
the previous owner took out the dash and "repaired it" not it has four other cracks in it now....IMHO its not worth fixing (dry rot, sun damage) best to take it out and replace them.
Funny it spends most of its life inside sealed garage (no windows) and its stilled is cracking...
Good Luck
Good Luck
He got his name from a local dealership, Eagle Buick GMC in Homosassa/Crystal River. I don't know if he would travel down your way.
Worth a try... Call Richard V.
Chuck
